With the blade cut and drilled to length, and the frame shaped and finished (BLO) it was time to add some tension to the frame to pull on the blade.
I was toying with some ideas, and ended up getting an IKEA steel wire hanger as the tension control. It’s quite simple, and uses 2 threaded ends one left hand one right hand, both pulling on the wire:
Putting tension on the blade using this method is not as easy I was hoping it would be and requires a pin to roate and thread those metal ends into their mating studs… I may end up just putting a standard hemp thread there at some point with a paddle, but test cuts were not bad, although the blade can rotate pretty easily – at least easier than I would like to. I’m not sure if this is due to not enough tension on the blade, or if that’s just how it is (never had a frame saw to compare to). I am guessing this is due to insufficient tension though… so again – may go for hemp thread with paddle later on:
The saw is surprisingly lightweight and feels very comfortable in use more so than I expected even with all the stainless steel hardware, although now that I used it – for size, I think I’ll make another smaller one for joinery (was hoping to have an all-in-one joinery+general cuts saw). For now this will work for what I need it for though:
Next I milled and rounded some mahogany for the handles. here is rough initial rounding with a #5:
I then turned it to size and shape, and drilled the core to accept the 1/2” stainless steel blade clips:
and Viola, the saw is complete (well, I do need to glue in the handles to the clips, but other that it’s done):
Thanks for watching,
Peace.
16 comments so far
chrisstef
home | projects | blog
5239 posts in 1174 days
#1 posted 358 days ago
Ill take mine in ash Purp ;).
That looks liks its going to be a well added tool in the arsenal of wood assaulting items.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
SPalm
4108 posts in 2050 days
#2 posted 358 days ago
Nice Purp.
That Ikea wire thingie looks interesting. I need to keep that in mind.
Overall though, the saw looks wonderful. I bet it will take some practice to get her to sing.
Steve
-- -- I'm no rocket surgeon
Lenny
1037 posts in 1695 days
#3 posted 358 days ago
Stellar job Sharon! You have created one beautiful homemade tool. Clearly something to be proud of.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
34369 posts in 2568 days
#4 posted 358 days ago
Great looking. Way to keep your eyes out for re-purposed attachments.
David Kirtley
1250 posts in 1166 days
#5 posted 358 days ago
That is great for a turning saw but I don’t think you will be able to get enough tension for the wide blades to cut well. My store bought ones have arms that are about 1-1/2 in wide by a bit over 3/4 thick. It takes quite a bit of tension for those wide blades.
As to the turning blade, I dunno. Mine stay put pretty well. The store bought ones have wooden pins (with metal plates and have quite a bit of friction. My little turning saw seems to not turn with tension but I thing that it is being pinned by racking the arms when tightening.
I converted the ones I bought that came with a threaded tensioner over to line tensioner. The threaded ones just never felt right to me.
Sylvain
465 posts in 667 days
#6 posted 358 days ago
To prevent unwanted handle rotation,
You may try puting O-rings
see the 5th picture on this blog :
http://cornishworkshop.blogspot.com/2012/01/oooo-la-la.html
or lock washers.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
489tad
992 posts in 1179 days
#7 posted 357 days ago
Very nice all the way around. Thanks for posting.
-- Dan I.G.N.
PurpLev
7741 posts in 1816 days
#8 posted 357 days ago
hmm, thts interesting Sylvain – I was doing some modifications to the saw to have more wood-to-wood friction between handles and frame, but if thats not going to change much, I’ll check out the o-ring idea – thats brilliant- thanks!
mafe
8055 posts in 1257 days
#9 posted 356 days ago
Wonderful build, I really love it.
Yes now you just have to build a set.
I lso love using the frame saws, just bought a bunch that I will restore so no more builds for me.
Hope life is sweet to you – peace,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
PurpLev
#10 posted 356 days ago
Thanks Mads. I think you had your fair share of building them – so you can take a rest ;)
Hope the new place is full of love
Mauricio
5114 posts in 1319 days
#11 posted 356 days ago
Great build Purp, I envy your metal working abilities.
mafe
#12 posted 355 days ago
;-) life is sweet.
PurpLev
#13 posted 355 days ago
David in reference to:
The tension that I do have on the blade seems sufficient as the saw cuts well – and straight. I am curious though to experience other saws tension first hand to compare.
David Kirtley
#14 posted 355 days ago
I have mine strung with Dyneema line. The low stretch stuff that they use for rigging on sailboats – 3.8 mm line with a breaking strength around 600lbs. When tightened, the blade is comparable to a backsaw on the shorter crosscut saw. I hardly get any deflection at all when sawing with it. My longer saw that I have a rip blade in, I don’t use as much tension. It is more comparable to a panel saw. I can make it deflect if I don’t saw straight.
Maybe I tighten them too much. I don’t have any real knowledge of what is “right” but when it is not tight, the saws don’t feel as good to cut with and don’t track as well.
To give some scale, here is the picture of one of mine I bought at Highland Woodworking, the blade is a bit over 1” wide.
For what it is worth, the blades I got over at Traditional Woodworker cut much better than the ones that I got with the saw. My smaller one came with a Japanese style blade tooth but I have taken it out in favor of a 9tpi crosscut blade.
PurpLev
#15 posted 354 days ago
Thanks for the input. from your description I think I have it tightened enough, and the saw cuts well and does not wander but stays in a nice straight line and cuts fast.
I think the japanese blades makes the cuts easier (smaller and more teeth) but I just don’t care much for the idea of teeth breaking and having to replace the entire blade for it – that’s why I built this saw to replace my japanese saw. I wanted a blade I could resharpen when needed.
View all comments »
