I wanted to do this for a long time and had the parts ordered and delivered a while ago, but one thing led to another and this was kept on the back burner and never saw the light of day. Ironically, it is now finished but still with no light of day as it is almost 11pm… All it gets is the light of the moon (which some may say is better).
I really liked benchcrafted wagon vise (even a free plug for them) But for what it is I think it’s a bit overpriced (for a vise). Don’t get me wrong, for their investments, materials, work done and considering this is not a mass produced and sold item, I don’t think they are overcharging for it. But as a vise, I feel it is an overpriced item (confused yet? don’t be!). If you have the $$$ and this expense won’t affect you – go for it, I think it’s of great quality and and you’ll get a good product. I personally can’t spend ~3 times what I spend on the entire workbench for just 1 vise and so I decided to build something of similar functionality (not on the same mechanical engineering quality – but something that will give me the same function at a doable cost).
The wagon vise was using a simple LV tail vise screw and a block of wood that travels across it and was completed a while ago (see previous post in this series) but what I really wanted to add was a wheel, as I find the long handles on vises to be less then user-friendly especially when you have to open and close them a considerable amount.
I ordered a 6” cast-iron wheel from Grizzly a while ago when I order a couple of other parts from them for ~$7 and using a pin punch I took off the LV vise T assembly:
As you can see, small hole in wheel not exactly matching the large hole on the vise head and will need to be enlarged:
I mounted the wheel on the lathe and enlarged the hole using a 3/8 drill bit to make enough clearance for a boring tool:
I should really get a 1/2” or larger drill bit to make a larger clearance hole, but since 3/8” is my largest metal drill bit, I had to use a smaller boring tool to start with which is also shorter. that means that with the wheel mounted as is, I wasn’t able to reach with the shorter boring tool throughout the hole, and had to mount the wheel the other way. After enlarging the hole enough, I moved onto a larger and stiffer boring tool to complete the hole:
And validated the hole sizing by comparing to the original part:
Not it was time to drill the pin hole. I mounted the wheel in the mill, and since the hole is drilled in a round surface and the drill will have a tendency to slip sideways, I used a block of wood for the initial pilot hole to keep it straight:
I then stepped up the hole in size with different drill bits until I got the 1/4” at which point I slid the wheel out of the way and using a hand drill and a long (somewhat flexible) 1/4” drill bit followed the top hole and transferred it to the lower part of the wheel since the wheel itself made it impossible for me to drill this through with regular drill bits:
Once I had the holes aligned I continued and brought the hole to it’s final size of 5/16” (I stopped at 1/4” since this is the only long drill I have from my days as an electrical contractor) and finished it off with a reamer to make the hole round and even to accept the pin:
A quick check on the vise looks good:
Drove the pin through, and ran it through a little test drive:
works great! no more long handle to have to deal with, this truly makes a big difference and with the tail/wagon vise there is so little pressure required that is just makes so much sense to have it there.
Now just to turn a handle for the wheel… no hurry there as even without one it still works wonderfully.
Thanks for reading,
Peace!
16 comments so far
mafe
home | projects | blog
8084 posts in 1286 days
#1 posted 640 days ago
That is a nice upgrade, and what a nice metal machinery you have.
Best thoughts,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
ellen35
2453 posts in 1629 days
#2 posted 640 days ago
ingenious!
MShort
1397 posts in 1615 days
#3 posted 640 days ago
Very nice. Thanks for the step by step instructions and photos.
-- Mike, Missouri --- “A positive life can not happen with a negative mind.” ---
b2rtch
2967 posts in 1245 days
#4 posted 640 days ago
Very nice!
-- Bert
SPalm
4174 posts in 2079 days
#5 posted 640 days ago
Sweet. That does really look like a nice mod.
Love the lathe.
Steve
-- -- I'm no rocket surgeon
Bob42
451 posts in 1987 days
#6 posted 640 days ago
Way Cool!! Very nice upgrade. I love that idea.
-- Bob K. East Northport, NY
Mark Shymanski
3958 posts in 1910 days
#7 posted 640 days ago
A very cool solution!
-- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2
34396 posts in 2598 days
#8 posted 640 days ago
Great looking upgrade. Nice job on the revisions.
Lenny
1055 posts in 1724 days
#9 posted 639 days ago
From concept to conclusion, well done! Kudos!
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
Dennisgrosen
10851 posts in 1312 days
#10 posted 639 days ago
great end job :-)
Dennis
moonls
382 posts in 1184 days
#11 posted 639 days ago
Your combination of engineering, metal working and woodworking skills are amazing!
-- Lorna, Cape Cod
charlton
76 posts in 1606 days
#12 posted 639 days ago
Nice. This was exactly what I was planning on doing. When did you get into metal working, though? :)
6526 posts in 2177 days
#13 posted 636 days ago
Great job on this, Sharon.
Nice tools, too!!!
Bertha
12906 posts in 890 days
#14 posted 636 days ago
That’s a really nice wheel. Where did you find that thing? After looking at the prices of the benchcrafteds, I’m looking at alternatives. Nice save. A wagon is a must on my new bench.
sIKE
1268 posts in 1951 days
#15 posted 636 days ago
Sharon,
As always, you are able to find the best of the functional and combine with the inexpensive…..
View all comments »
