Beads Box #8: Drawers Construction
Blog entry by PurpLev posted 01-02-2011 04:14 AM 8821 reads 0 times favorited 7 comments Add to Favorites Watch
« Part 7: Fill, File, Fo - The filling of Them Pores Part 8 of Beads Box series Part 9: Stringee »
Today I was able to resaw some 3/4” boards to make the 3/8” (slightly less) material for the drawers, cut the parts, and joinery, and put it all together for a dry fit.
I had originally planned on having 9 individual drawers in the center compartment, but for lack of materials and time, I ended up making 3 large drawers and I’ll put dividers in those and see how it goes, for ease of use it might be better to make 3 smaller boxes for each drawer so that each one can be taken out individually.
The drawers are all using finger box joints, but unlike a regular box where all parts are flush at the bottom, I wanted to have a 1/8” step on the bottom of the fronts so that they’ll act as depth stop against the drawer dividers. In order to get that step I simply started both the fronts and the sides of the drawers aligned flush with the finger-joint-jig spacer which caused the fronts to be 1 finger lower and since I’m using 1/8” fingers it game me the desired step down (My Finger Joint Setup):
the bottoms are made of masonite and will not react with humidity, the sides/back is poplar, and the fronts are oak from pallets that I disassembled:
Overall, lots of finger joints which takes a bit of time, but it all fits perfectly. Normally I would route the slot for the bottoms with a start and end stops so that the grooves will not carry through the ends and show on the sides of the box, but in this case I’m going to veneer the drawers fronts so it doesn’t really matter.
Next, cleaning up the drawers, making some final adjustments/dividers in the large drawers, glue them up, set slides for the lower set of drawers (so that they don’t ride on the ‘table’), veneer the fronts and add knobs and I’m close to finishing up (as in putting finish on them)
not much, but still some work to go through – the old 80/20 concept, you do 80% of the project in 20% of the time, and then 20% of the project in 80% of the time…
Thanks for reading,
Peace
7 comments so far
View spunwood's profile
spunwood
1202 posts in 3074 days
#1 posted 01-02-2011 04:38 AM
I never heard that 80/20 before, but it sure seems true…similar to inspiration vs. persperation. I fiddle and think for hours, about a project. Some aspects take much longer than expected…some dreaded parts I do differently than I planned and take just an evening.
-- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν
View bigike's profile
bigike
4055 posts in 3527 days
#2 posted 01-02-2011 05:06 AM
wow, you have some patience to sit and cut all those box joints but it’s worth it. The box is coming out very nice. The free wood from the pallets help alot huh? I get the same wood from my job, there is alot of oak,cherry,and sycamore. I think i found some walnut this week though, it looks like it. I wish i had brought it home for the weekend but its cool monday will be the day then I’ll need a project to show it off.
6866 posts in 4218 days
#3 posted 01-02-2011 06:28 AM
Hi Sharon;
You seem to be in a specialized niche…small, yet complicated projects.
But, it’s looking good.
View PurpLev's profile
PurpLev
8548 posts in 3887 days
#4 posted 01-02-2011 07:05 AM
I agree Lee, I was just thinking the same thing this past week “why oh why can’t I just make something a bit less complicated…” but I have not gotten any answers… oh well.
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3275 days
#5 posted 01-02-2011 09:17 PM
Yes, Sharon, but wouldn’t simple be a bit boring?
This is really coming together nicely.
View mafe's profile
mafe
11771 posts in 3328 days
#6 posted 01-03-2011 07:36 PM
Admire the patience.
Best thoughts,
Mads
PurpLev
#7 posted 01-03-2011 10:37 PM
Martyn – for boring I use the drill press ;)
Thanks for the comments. currently waiting for the finish to dry….
