Jack and Jill,
Went up the hill.
To fetch a pail of water.
Jack fell down,
And broke his crown,
And Jill came tumbling after.
Then up Jack got,
and home did trot.
To old dame dob,
Who fixed his KNOB,
With vinegar and brown paper.
What does this have to do with a machinist toolbox? well. I also had to fix my knobs, but not with vinegar and not with brown paper (although the walnut IS indeed brown)... read on:
I wasn’t feeling too well today so I probably should not have done much work, but being so close to the end I couldn’t resist.
The drawer pulls
My original concept was to use a rectangular pull indented into the drawer front and have a 1” hole to allow finger access to the pull:
The concept was good, and I like the design, however it entails a practical flaw – at 1” diameter hole, there isn’t enough room to fit 2 fingers in order to grab the pull. Back to the drawing board…
I thought about constructing something similar to this:
But at the scale I’m working with I decided to go with something more mechanical put and simple. The idea is – I needed to figure a way to create some surface that would counter the pulling force of a finger, and I came to the following pull:
It will fit into my 1” diameter holes, allow ample access for 1 finger which will then catch on the back angle. In theory this can also be done without the back ‘disk’, but since I had drilled 1 pull hole in a drawer front too deep (not too deep – that drawer had different mechanics that blew the drawer bottom through the hole) I figured this would cover it up, Also it makes alignment in the 1” hole real easy as it fits snugly inside and won’t fall off due to gravity.
To make the pulls I started with a hole saw, 1 1/4” diameter. The 1 1/8” diameter hole saw created a plug that was a tad too loose in my holes so I chose on going oversized than undersized.
Next I used my lathe and turned those plugs to a piston fit in the holes to within 0.001” in diameter – not really necessary, but it was good practice on turning to specific size:
Once I had a good fit, I pushed the plug into the drawer front, and marked the depth. At that point I was able to cut off the excess on the bandsaw. The parts being so small and round (hazard) were not an easy cut. I used wooden screw clamps as a sled since it has a good amount of surface that can safely ride the saw table and cut the line:
Once I had the sized plugs it was time to shape the pulls. Again using the same technique with the wooden clamps I held the parts on the ‘front’ of it, and cut 2 lines. 1 parallel to the back of the pull, and another angular to make the front of the pull:
The angle should be ~30-45 although it isn’t that relevant and won’t really be seen anyways. The important thing here is to create a back angle surface that will counter the pulling force of the finger. The shallower the the angle the more material is left on the pull making it more stout and less delicate. I freehand cut all of the pulls without worrying about internal appearance, and put 2 coats of poly on them to enrich the color more than any other reason:
I still haven’t decided if I’ll glue those in (silicone) or screw them in. At the moment I’m favoring the silicone to avoid introducing another material to the drawers fronts.
While at the saw, I also cut the 4 legs, and the parts for the front panel. this baby is coming to a complete state soon.
Thanks for reading,
Peace.
12 comments so far
home | projects | blog
34370 posts in 2570 days
#1 posted 878 days ago
Sharon: I see that I kicked you into the hole filler upper. Nice concept and creation.
fernandoindia
1002 posts in 1113 days
#2 posted 878 days ago
nice creation on the pulls. be watching the final outcome. Great blog Sharon., Thank You
-- Back home. Fernando
Craftsman on the lake
2021 posts in 1607 days
#3 posted 878 days ago
I think what you made is much better than the original idea. Well executed! Can’t wait to see them installed.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://gagnerwebsite.com/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
Jamie Speirs
3680 posts in 1026 days
#4 posted 878 days ago
A very unique knob.
That is thinking inside the box. :)
Thanks for sharing
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
Dennisgrosen
10854 posts in 1285 days
#5 posted 878 days ago
looking good sofare but will the design change work ….
we just have to sit excided on the flat and wait in patience
till the master himself reveal the secret with bravur ,bells and wissels
thank´s for sharing the toturial
take care
Dennis
ellen35
2442 posts in 1602 days
#6 posted 878 days ago
I actually like the new ones better, Sharon. Of course, if you really don’t like it, I’d be glad to come buy and pick up the whole thing so you can start over ;-))
This is turning out to be a beautiful project.
Ellen
twokidsnosleep
1023 posts in 1143 days
#7 posted 878 days ago
Good problem solving skills and thoughtful enough to work out the bugs before cutting for all the wrong design pulls.
I would have cut first, asked questions later …..and screwed it all up
It is really coming along!
-- Scott "Some days you are the big dog, some days you are the fire hydrant"
nobuckle
1046 posts in 930 days
#8 posted 878 days ago
Those are going to look great. It’s great to have the skills to work in such a precise manner. Having the machines to carry it out is even better. Look forward to seeing the finished chest.
-- Doug - Make an effort to live by the slogan "We try harder"
Brad_Nailor
2449 posts in 2127 days
#9 posted 878 days ago
Sharon…great idea, great Sketchup model, great execution! That box is going to be an heirloom piece!
moonls
376 posts in 1156 days
#10 posted 877 days ago
Your problem-solving skills are great! I cin’t wait to see the final post on this project.
-- Lorna, Cape Cod
jm82435
1217 posts in 1911 days
#11 posted 874 days ago
Nice job. I like the knob design also. It looks like it gives more clearance for fingers.
When you said you were making it to house your lathe tools, I was thinking wood lathe.
I use my metal lathe for wood projects too. Yours looks nicer with the quick change tool post.
What type of insert do you use when turning wood?
-- A thing of beauty is a joy forever...
PurpLev
7753 posts in 1818 days
#12 posted 874 days ago
jm82435 – Thanks. I do not use inserts. I have a some brazed carbide cutters that I got with the lathe, and am using those with the wood in this example, I have recently switched to HSS cutters though which I can grind myself to a better point.
