Machinist Toolbox #3: Carcass parts ready for some groovin'
Blog entry by PurpLev posted 12-12-2010 08:25 PM 5091 reads 0 times favorited 8 comments Add to Favorites Watch
« Part 2: Milling some Lumber Part 3 of Machinist Toolbox series Part 4: Bad Weather, Kitchen Bender »
Yesterday was such a beautiful day, wasn’t too cold, and the sky was blue (today is cloudy and rainy). I was fortunate enough to be able to use the day for some woodworking.
I am at the point where I usually run into trouble. I have a tendency to want to work on the joinery and the problem is that I usually do that before I have all the parts ready leaving me with some parts that go together, but still require work to get the rest of it as well. This time around I decided to get all the parts ready before I get into joinery.
I ended up having to cut the 6” boards I had in half to make the final side panels of 10” since keeping them at full 6” width and glueing up another 4” board on one side would make them asymmetrical in an unpleasing manner.
I made the 2 side panels made of 3 vertical boards, and a top horizontal breadboard to (1) keep the vertical boards in line (literally), and (2) provide end grain on the front of the toolbox to mate with the front top rail which makes the top compartment and lid.
I had extra material length, and currently cut the sides 2” taller than the plan called for. I’ll see how it looks proportionally and if it works out will give me extra 2” for drawer space, if not- I’ll just cut it to it’s planned height before cutting the joinery and dadoes.
I also glued up the bottom panel, and like the sides, ended up making it 2” longer making the toolbox wider. If it works out visually that will give me a bit more space, and if not – I’ll cut it shorter.
For the drawer dividing panels, I ended up changing the original (tentative) plan of using solid panels, and decided to make those out of frames which would:
1. Reduce material needed – this will make it slightly lighter, and also makes it easier for me as I won’t have to make up really large panels
2. Adds dimensional stability – since the parts are narrower they are less prone to expand, and also since the grain goes in both directions it’ll help resist the changes slightly (the main thing is the parts being narrower though since if the wood decides to move – it’ll move)
I still need to make the vertical dividers, but those are small and easy to machine, the more important parts I’m still missing and need to make are the 2 panels – top (lid) and back, both are large, and I’ll need to get those done before I can put the whole thing together. So far this is what I’ve got:
So far so good, I hope this train keeps on going.
8 comments so far
View Dez's profile
Dez
1166 posts in 4040 days
#1 posted 12-12-2010 08:27 PM
Looking good – progress being made!
-- Folly ever comes cloaked in opportunity!
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2819 days
#2 posted 12-12-2010 09:06 PM
Coming along nicely.
jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View Dale J Struhar Sr's profile
Dale J Struhar Sr
493 posts in 3093 days
#3 posted 12-12-2010 09:08 PM
Time and patience .
-- Dale, Ohio
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3078 days
#4 posted 12-12-2010 09:30 PM
looking good sofare
and for the train thing you just have to ceep enoff coal in the tender and water on the boiler
to ceep the fire up to preventing the steam from going down…LOL
take care
Dennis
6851 posts in 3942 days
#5 posted 12-12-2010 11:58 PM
Looks good Sharon.
35111 posts in 4363 days
#6 posted 12-13-2010 07:25 AM
Keep the parts flying.
Well not flying, but keep them going.
Looking nice.
View moonls's profile
moonls
412 posts in 2949 days
#7 posted 12-13-2010 03:34 PM
Your project is shaping up nicely! And I think mahogany was the perfect wood to use for this project. Keep up the good work!
-- Lorna, Cape Cod
View helluvawreck's profile
helluvawreck
30765 posts in 2829 days
#8 posted 12-14-2010 03:03 PM
Sharon, this is very well done and I am enjoying it very much. Keep up the good work. :)
