As mentioned in a previous post, I was in the midst of planing quite a bit of hard maple, when my planer decided it was not hungry anymore, and would not feed the lumber under any circumstance – I tried the “here comes an airplane”... no go. I tried the “I’ll get you ice cream if you finish all the lumber” – nope. I tried “I’ll tell mama you didn’t finish your wood” – nada.
So I decided to play doctor and open it up and see what’s up. no, it was never a fantasy of mine, but I do like to fix my own things (as long as it’s within my capacity to do so).
The roller mechanism is fairly simple. 2 rods that the rollers are mounted on, 1 rod (front) is being driven by the cutterhead via a gear mechanism that reduces the RPMs (and integrates with the speed selection switch). Then, the front rod is driving the back rod by means of 2 sprockets and a chain between them. real simple.
To get to the roller mechanism, you use the supplied wrench and remove 3 set screws:
the entire side cover comes off to reveal the mechanism where I found the front sprocket broken in half:
Actually, I only found half of the sprocket – I have no idea what happened to the 2nd half, which made me wonder if it even broke recently or before I got the planer. Regardless, I ordered a replacement part for $3 from a local dewalt service center. real nice guys in Billerica, MA.
Here you can see the half sprocket with it’s replacement part:
it was just a matter of putting everything back again (with the new part obviously) and call it a day. mind you -the sprocket has a lip on 1 side, and should be installed with the lip facing inside (towards the planer) – for over excitement I installed it reversed – yup, you can probably imagine where this is heading….
So, I installed everything back together – except for the cover, and turned the planer on – lo and behold, the planer is running, and the rollers are moving ! YEAH! good stuff right there….
1….
2…
SNAP!
now the other sprocket broke in half :( I have a strong feeling it’s because the sprockets were each installed opposite (one with lip inwards, one with lip outwards) but since the other sprocket broke and fell out I can’t guarantee this. the other alternative which I really hope is not the reason is that there might be something else that was causing the sprocket to break.
So, back to ordering another sprocket (I’ll get a few just in case as backup).
This is theoretically how you’d fix the rollers, although you may want to pay more attention to which way the sprockets are put in so that you’ll actually be fixing it and be done with it. in my case – planer is still out of commission. I ended up hand planing/thicknessing the rest of the lumber for the cutting board I’m working on. not hard, but just takes more focus as you have to pay attention to flatness and thickness per board manually rather than just shoving all boards into the planer and worrying not.
On the other hand – I had success fixing my Lathe. Since it’s non woodworking related, I started my own blog for that, you are all welcome to check it out as it’s focused on machining and metal/solid material work. you can read it HERE
14 comments so far
ChuckV
home | projects | blog
1751 posts in 1696 days
#1 posted 955 days ago
I hope that you get your planer working again soon. Based on your experience, if I ever need to replace a sprocket, I will buy a few of them.
Are the sprockets metal or plastic?
-- "Too much hurry ruins the body. I'll sit easy … fan the spark" - I. Anderson
PurpLev
7753 posts in 1818 days
#2 posted 955 days ago
these are metal. it seems like they are cast metal of some sort, easily broken if put under stress.
NBeener
4856 posts in 1343 days
#3 posted 955 days ago
Now THAT’s a bag of downers :-(
Hoping the third time’s a charm !
-- -- Neil
34370 posts in 2570 days
#4 posted 955 days ago
Good luck on the re-rebuild
PurpLev
#5 posted 955 days ago
Thanks. hopefully next time will be the last.
shopguryl – thanks!. that’s exactly what I plan to do to make sure nothing else might be lurking in the dark – spin it by hand, and check it closely before I power it up. then have a couple extra sprockets at hand if it does pop up again. the idea that maybe both sprockets got hit at the same time, while one was just waiting to fully crack makes sense. we’ll see how it goes next week when the parts arrive.
6499 posts in 2149 days
#6 posted 955 days ago
Hi Sharon;
Some days it bees that way, right?
At least now you know.
Bearpie
2474 posts in 1187 days
#7 posted 955 days ago
They are made with soft metal so they break instead of completely ruining the planer. It sucks but the alternative is worse.
Erwin, Jacksonville, FL
-- Erwin, Jacksonville, FL
PurpLev
#8 posted 955 days ago
Thanks Erwin – I agree! I would machine a new sprocket of better material, but at the risk of messing a more substantial component in the planer – I’d rather get the proper soft metal replacement part that would break first.
Mark Colan
142 posts in 1015 days
#9 posted 955 days ago
I had a nice laugh with your words, spoken like a parent trying to feed the child. If the gears were installed incorrectly when the machine was built, and it was possible to do that, then I would call that 1) a design flaw and 2) a failure of quality control.
Anyway, good luck with it!
Mark
-- Mark, hack amateur woodworker, Medford (greater Boston) MA
Gary Fixler
1000 posts in 1551 days
#10 posted 955 days ago
ARGH! All of my pain is returning. Yours is a sprocket. Mine was a bearing. I also ruined my first replacement and decided to buy a few as backups after that. I feel your pain. Planers are crap. Best of luck!
-- Gary, Los Angeles, video game animator
ellen35
2442 posts in 1602 days
#11 posted 955 days ago
Sharon,
You are fortunate to have parts available so close to home.
I’m sure you’ll get to the bottom of this one… you always do!!
Ellen
Cato
642 posts in 1482 days
#12 posted 955 days ago
Yuck, I regard my 735 almost with a sense of awe everytime a rough board goes in and a beautiful grained piece of wood emerges from the other side!!
I hope it was just the sprocket that failed and not failed bearing stress related, but have to wait and see.
However, once you get it fixed up you will have that sense of pride in doing it yourself and having learned about the mechanics of your planer. Sounds nice to say anyway, sympathy I guess for one that has to go through the agony of a downed piece of equipment. ;)
Thanks for sharing with the pics as a lot of us 735 owners can learn from this.
ROY53
73 posts in 1347 days
#13 posted 955 days ago
Look real hard for the broken piece. It didn’t vaporize. That may be binding up the works.
-- Roy L, Arizona
Dez
1097 posts in 2247 days
#14 posted 947 days ago
Those sprockets are about half the thickness of the ones on my Jet!
The second sprocket may have broken at the same time as the first! (I replaced the ones on my Jet when I was planing some rough Incense Ceder siding – it ran 3/4” to 1 1/4” and I didn’t check to make sure if I had it set to the max thickness! Mine quit before I could start planing another board)
It may have broken right when it quit working the second time!
All the strain/pressure – however normal, will take out the weakest part! (Wear and tear or oxidation of the plastic, whatever.)
Either way you have done the maintenance and replaced worn parts so it should be good for a while! (Unless you also needed to replace any bushings or bearings!)
I believe this is the first time I have posted on one of yours PurpLev! I just wanted you to know I feel for you and have been there.
NOTE!
Any critique perceived is from my experiences and wanting others to be able to avoid my mistakes. (I had my planer apart 5 times in one week AND ended up ordering spares to keep on hand!)
That Little Jet planed an estimated 50 lineal feet before I had to replace a second set of gears AND the feed roller bushings! (I should have replaced them along with the first set of gears!)
After that I ran an estimated 5K lineal feet without a problem. (It is probably time for another set soon?)
OH WELL, such is Woodworking! :-)~
-- Folly ever comes cloaked in opportunity!
