Disclaimer: This blog follows my Magen David Board that is already finished and posted here
Once everything was glued up into a single slab, it was time to plane it flat and parallel. one of the strips I jointed happen (don’t ask me how…lol) to be jointed off square, throwing the last 4-5 strips in the glueup off flat (mostly flat). I was tired at this point, and just figured I’m not going to rejoint it, but will pay the price and plane it all down at the cost of having a thinner board – it didn’t seem like it was going to take off too much material, but more than what I had hoped for.
I took the board to the garage, and went at it with hand planes. Unlike planing cross grain, planing end grain is a serious task, the bites are hard, the setting needs to be such that the plane will take ultra thin shavings in order for it to be able to handle the shearing force, and the lumber is not very friendly to the blades – I think now that I’m done I’ll have to resharpen all plane blades just because of this one job.
I was able to decently plane most of the board down flat , but those last 4-5 strips were too low that I wanted to keep at it with this method.
The next day, I reconfigured my old drill press table that served me as a glueup guide, and was not setup as a planing base along with 2 jointed flat support boards that are slightly taller than my cutting board.
I shimmed the cutting board between the 2 ‘rails’ so that it won’t be moving about, and using my old workbench-planing-sled and a 1-1/4” mortising bit, I went at it taking ~1/32 passes until I was able to level out the board on one side, flipped it (and put a 1/8” masonite sheet under to lift it up a tad bit) and did the same thing to the other side to get a flat and parallel board – rough looking:
After that, I went back to hand planing it flush and smooth. still not an easy task, but at least the bulk of it was done. remember – bevel the edges slightly so that you don’t chip it as your planing through it.
Now that I had a flat board to work with, I trimmed it on the TS tot make it square on all the edges so that I can edge treat it with the router table.
I then (finally since setting it halfway up) was able to utilize my router table and the LS positioner to get:- A nice consistent bevel around the edges (top and bottom)
- fingers handles on both sides – this was real nice since I setup stops on left and right of the fence, and was basically following along, while taking 1/8” passes to get the total of ~2.5” deep pockets in a matter of seconds – no guessing, no remeasuring – once the stops were set, they kept their location throughout the entire process. I’m really liking this fence.
- V shaped juice grooves. again – setting up the stops on both ends, and sneaking up on the final stops was easy with the precision of the Incra positioning method.
what I eventually got. was this:
A bit thinner than I had planned for, the geometry is a bit off from the original lines I had designed for it, but I think it came out great! I’m really liking this one, and the thickness actually looks more elegant than the original thicker design.
With a bit of mineral oil. this project was done and done, and can be seen here:
After applying the oil, the board twisted corner to corner. at first I freaked out, but then it hit me that this might be the effect of the oil and once it is fully absorbed evently, the board will naturally balance itself out – which it has, and is back to flat.
So, the project is done, Lessons learnt, Experience gained, and I’m pretty happy with it all. All in all, even though there was a lot of fixing and dealing with the improperly milled lumber – it was a fun project to work on, and I already have a couple more in mind.
Thanks for reading,
Peace.
14 comments so far
lew
home | projects | blog
9036 posts in 1953 days
#1 posted 1052 days ago
Great series, Sharon!
I picked up quite a few tricks from your experiences, thanks!
Lew
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
PurpLev
7819 posts in 1846 days
#2 posted 1052 days ago
glad to hear that Lew – mission accomplished!
34396 posts in 2598 days
#3 posted 1052 days ago
Sharon:
A great completion to the board.
PurpLev
#4 posted 1052 days ago
Thanks Karson, as I was routing the details, and it started to shape up the accomplishment feeling kicked in. finally a finished project.
dub560
603 posts in 1110 days
#5 posted 1052 days ago
looks great pulplev
-- Life is enjoyable especially when you borrow from people
6526 posts in 2177 days
#6 posted 1051 days ago
Hi Sharon;
Really very nice!
HokieMojo
2084 posts in 1925 days
#7 posted 1051 days ago
I enjoyed reading your about your progress. thanks for posting and showing what great results you achieved!
Robb
645 posts in 2131 days
#8 posted 1051 days ago
Great looking board!
I have those same earmuffs, btw, and love them.
-- Robb
SPalm
4174 posts in 2079 days
#9 posted 1051 days ago
Crimmineee. I forgot how many steps there are to make a board. I just read post 1 to this one, and I am exhausted. Good job, and a really nice looking board.
The grooving on the top and at the end really adds a professional touch.
Steve
-- -- I'm no rocket surgeon
PurpLev
#10 posted 1051 days ago
Thanks guys. glad you enjoyed. hope you enjoyed it at least as half as I did ;)
Steve – it’s amazing how many steps are taken to make a board of wood into a board of wood isn’t it?
Jimi_C
506 posts in 1432 days
#11 posted 1049 days ago
Funny, after just posting on #3, I noticed you used maple and cherry – exactly what I’m planning on doing :) I’m staying away from the triangles though… this is my first butcher block and I’ll be happy if I just get the cubes right :D
Also, I plan on using the router setup to flatten mine too. I’m going to glue up long boards that are 7/8” x 1”, then cut them in 2” sections to turn them up for the end grain. I plan on doing the long glue-ups 4-6 at a time, so I can run them through my planer on edge to try and keep them consistent… we’ll see how that goes after the first batch though.
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
PurpLev
#12 posted 1049 days ago
Sounds like a good idea Jimi_C. If you plane/thickness all your sub-blocks at the same time you can also ensure that they are all of the same thickness – although since you will be then flipping them on edge – it may not really matter that much. Good luck with it. looking forward to see the posts and pictures :)
Jimi_C
#13 posted 1045 days ago
I was going to use the router setup for the end grain part. I’m going to use the planer for getting a consistent thickness on the boards after they’re face-glued. I don’t want to deal with individual blocks like yours, since they’re such a pain to get even like that.
PurpLev
#14 posted 1045 days ago
Jimi- the only reason I slowed things down is because I was drying to draw a picture with the triangles that is not consistent from one strip to the next. If I was doing a squared uniformed board – I’d just plane everything down with a planer, and not worry too much about it. it would have been much faster and less of a pain. go for it!
