This project is a fine example of the 80/20 concept. it takes 20% of the project time to complete 80% of it, and then, 80% of the project time to finish the last 20% of the project.
As it gets to the details, things take longer to think through, plan out, cut…mill…glue… and finesse. this time it’s the leg vise Chop, and although not completely finished (still need to trim, round off, and apply BLO), it’s construction is done.
I was originally planning to use one large 10/4 board for the chop, but I didn’t have anything of that size that would work well. the only part I had was mahogany, and it’s not as hard as the rock maple, and I didn’t think it would work well for a vise jaw which gets abused, and needs to counteract pressure. I decided to use the bowling maple strip cutoffs, and laminate them to form the chop:
The lamination wasn’t as thick as I wanted, and I also wanted to give it an accent and something ‘different’ so I resawed the cutoff piece from the endcap (of the top) into 1/16” strips for the next step.
I cut a curve in the chop, which keeps the top of the chop as wide as possible (for clamping purposes) but narrows the bottom so that it’ll be easier for me to drill for the drawbore pins. Also the bottom of the chop doesn’t really need to be wider then the bench leg anyways. I then used the cutout curved parts as cauls and glued the 1/16” mahogany strips to the maple lamination:
I did one side at a time but glued all laminations at the same time. for future reference, I should prepare the veneers better- they weren’t uniformed and smooth enough, which caused some minor gaps. in this case, nothing to worry about -I just want to get this thing done, the errors can be easily fixed at a later time.
After glueing the veneers on the curve I repeated the process for the straight edges while making sure it’s butted against the curved veneers. I also mortised the chop and drawbored the (milled) maple parallel guide:
this time I drilled the offset holes for the drawboring – in the RIGHT place… lol. (I actually had to make sure, so that I don’t repeat the same error again).
After that, I placed the chop in the slot for the parallel guide, I took the hole-saw drill-bit I used to make the hole for the vise screw in the leg, and placed it in the hole in the leg so that the bit protrudes toward the chop, then I pushed the chop all the way flush with the leg, aligned it properly, and from the other side, tapped the drill bit so that it’ll mark the chop where the hole should go. I took the chop out, drilled the hole for the vise screw where it was marked, and installed the hardware:
action is still not smooth (not the screw, but the parallel guide has friction against it’s slot), I never used a leg vise before, so I’m not sure if that’s just to be expected, or not. I’ll try to plane the parallel guide in height so maybe it won’t have as much resistance. other than that – when this thing closes it’s like an Alligator jaws – it grips like there’s no tomorrow.
next I’ll round off the top and bottom, and plane the top flush with the table top, chamfer the front edges, and coat this with boiled linseed oil like the rest of this bench.
Edit: OK, I was able to round off the top and bottom of the chop, plane it flush with the top of the bench, chamfer (with a ) the edges, and put a couple of coats of BLO (1 more to go):
I also planed the parallel guide in height slightly, and rounded off it’s edges so that there’s less material in contact with the top and bottom of it’s slot – it now slides in and out much much smoother, with a coat of paste wax it would be even better.
On the same note – talk about timing – I just found a pair of rollerblades that someone threw away – I’ll see if I can incorporate the wheels like Jameel at Benchcraft did (although these are bigger wheels then skateboard wheels… so maybe I’ll have to look for something smaller)
10 comments so far
sIKE
home | projects | blog
1094 posts in 646 days
posted 102 days ago
Wow that is very nice looking leg vise!! I’ll bet you will get a lot of use out of it.
Not owning one, but doing lots of reading and living vicariosly through others, my understanding is the parallel guide should glide very smoothly. My understanding is the leg vise have a habit of sagging slightly causing the guide to bind a bit. Here is a link on how Khalaf resolved the issue.
PurpLev
2732 posts in 540 days
posted 102 days ago
Thanks sIKE, I read, re-read, read it again, memorized, and sang that blog when you first showed me that bench – I will probably end up doing something similar at a later date, but for the time being – I was hoping it would work smoother “out of the box” ... maybe some finessing…
sIKE
posted 102 days ago
Here is a good pic of the the roller.
Also a link to the Glide, I know you are not interested in a purchase, but the videos at the bottom show the leg vise and rollers in action…I now know how to make one for myself…
charlton
42 posts in 301 days
posted 102 days ago
Nice job on the vise. Hopefully, you’ll get all the quirks figured out but it’s impressive so far.
Todd A. Clippinger
5632 posts in 991 days
posted 102 days ago
This has been fun to follow.
ellen35
529 posts in 324 days
posted 102 days ago
I’m sure you’ll bring this little thing to the LJ Picnic next month…all finished!
Did you order the flatbed truck yet???
Ellen
-- Ellen on Cape Cod
PurpLev
posted 101 days ago
Thanks guys,
Ellen, no flatbed truck, but I did make reservations with a moving company – I might need some help unloading this though… ;)
SPalm
944 posts in 774 days
posted 101 days ago
That is really sweet. Good Job Sir.
Steve
blackcherry
730 posts in 715 days
posted 101 days ago
Bravo my good man the journey was a blast to view, thanks for sharing your adventure. This one will always be a memorable one on the site….Blkcherry
PurpLev
posted 99 days ago
Thanks guys, I actually added an updated photo of the Chop after being detailed and finished. it now works pretty great, and doesn’t get stuck – the motion can definitely be improved, but no more complaints from me – it works well!
almost there…. almost finished.
