Techniques & Methods #2: Fixing Messed-up Blind Dovetails
Blog entry by PurpLev posted 110 days ago 618 reads 0 times favorited 13 comments Add to Favorites Watch
« Part 1: Scary Sharp Method Part 2 of Techniques & Methods series no next part
As I mentioned in my recent workbench blog, I had used inverted dovetail joinery to connect the skirt of the benchtop to the endcap. just like Arabian Nights, there are 1001 stories why joinery can get screwed up- mine were rushing + miscalculating + lack of experience + other. All of these matter not, and the end result is a misaligned, crooked, awfully looking, and unacceptable dovetail fit:
Crooked Misaligned Blind Dovetail
you can plainly see the tearout and large gaps between the mating parts, and the misalignment on the bottom tail and it’s socket.
Obviously the ‘proper’ way to do things is to keep on practicing to finesse and perfect your joinery. BUT, learning to fix and clean mistakes is also a skill worth having for those times when things just ‘seem’ to happen.
This is a workbench, and the dovetail does it job – just doesn’t look too nice. I could have left it as is, and it wouldn’t make any functional difference, BUT. I preferred to clean this up, and accomplish 2 things:
1. have a nicer looking bench and dovetail
2. learn a new skill, and see if my theory would prove itself to be useful.
my idea seemed to have been fruitful!
Since the gaps are in endgrain, I figured it would be easy to blend cutoff pieces since endgrain does not have grain patterns that would be broken by a patch. what I did was slice cut off pieces of same material into small wedges, coat them with glue, and pound them into the visible gaps:
Wedges in Blind Dovetail gaps
(in this photo it’s actually the 2nd filling of the remaining gaps after the initial filling of larger gaps)
once dried, I pared the excess material off, and planed/trimmed the endgrain flush with the tails:
Fixed Blind Dovetail
Some of the fillers can still be seen and could be fixed a bit more/better, while other fillers are completely invisible. after a little more planing and scraping this looks even better, and after a coat of finish this one is good enough for the workbench – maybe in other situations I’d push for a tighter look, but for this purpose I am very satisfied with the result – hell of a lot better then the starting point.
Hope this can be of help,
Peace.
13 comments so far
View Gary Fixler's profile
Gary Fixler
646 posts in 274 days
posted 110 days ago
Why not just smoosh some walnut-colored wood filler in there? You could even squeeze some Titebond III in there. It dries a pretty dark brown, and would blend the two surfaces together with no gaps. You could even coarse-grit sand some walnut into the glue first, mix it into a slurry, and moosh that in there. That would help keep it from being a gummy glue filling, and it would probably really disappear, especially after planing or sanding (gasp! do you allow sanding anymore with your plane-lust? ;)
It does look a lot better, but I’d love to see your pretty dovetail work get all perfect suddenly, and I think something like the above would do it.
-- Gary, Los Angeles, video game animator
View himcules's profile
himcules
16 posts in 632 days
posted 110 days ago
you could also make the saw dust/glue wood filler mix so its the same exact color?
either way, very nice fix. for a work bench, no one will notice except for you…
20554 posts in 714 days
posted 110 days ago
Nice recovery, Sharon. This is a nice technique to dress up the gaps on the dovetails. For those of us who are struggling to become proficient at hand cutting dovetails this is a nice technique to learn.
View Cato's profile
Cato
138 posts in 205 days
posted 110 days ago
Hey Purp, though I have never cut a dovetail of any kind, we all know why you had to fix and dress it up even though it is a workbench and will be used as such. Because we become a bit obsessive about the finish look of a project no matter our skill level.
I think its looking real good and what you are teaching yourself in the project is obviously enhancing your skills!!
View PurpLev's profile
PurpLev
2732 posts in 541 days
posted 110 days ago
Thanks guys,
Gary, himcules – long grain and end grain have very distinctly different appearances and features. I believe that wood filler, or glue+sawdust (aka homemade wood filler) works well to hide gaps/craps between laminations of long grain, or in long grain where there are no eye catching grain patterns that can be visually broken. for long grain where there are grain patterns – I’d patch the mistake with another thin piece of long grain and try to match the grain-patterns – still won’t use wood filler. in my case I think wood filler would be very visible and will take away from the elegance of the joint, and since the fix I used was easily accomplished and completely invisible, I think it was a more fitting solution for this particular case. also there is no goo to mess with, and nothing spills.
Scott – you hit it with a nail. I think we need to get better at things so that we won’t have to fix them – but fixing is also a good skill to have on those occasions where you just have to fix something and fix it good.
Cato – that is correct. we just want everything to be the best they can be. the more we push ourselves, the better we become.
View sIKE's profile
sIKE
1094 posts in 646 days
posted 110 days ago
Sharon,
Very vice recovery! I have used the same technique before, it worked very well for me also.
Also glue will fill a gap in but it has no structure to it and would eventually fail. As for the glue and saw dust mixture, not a big fan. I had to use this technique on my last project and the color of the mix always ended up lighter than my wood. Glue’s short open time makes it real hard to get a matching color quickly (especially in 105 degree temp like I see down here in Austin)
View ratchet's profile
ratchet
299 posts in 679 days
posted 110 days ago
Sharon; Very nice solution! Thanks for sharing.
View lew's profile
lew
4475 posts in 648 days
posted 109 days ago
Sharon,
When I was learning to hand cut dovetails, I mentioned that I was having the same trouble, to an antique collector friend. He laughed and took me to see his collection of expensive blanket chests. Practically everyone of the chests had a similar fix to what you did. Seems the “old masters” didn’t worry too much if the fit wasn’t perfect. I saw little shims at the bottom and sides of the tails and pins. You had to look close, but they were there.
I’d say you did just the right thing.
Lew
25794 posts in 1293 days
posted 109 days ago
Great solution and it’s starting to come together. (Pun intended)
View blackcherry's profile (online now)
blackcherry
730 posts in 715 days
posted 109 days ago
I like what I’m see here, right before my eye’s. The making of self-taught craftsman….Blkcherry
View abie's profile
abie
112 posts in 663 days
posted 109 days ago
Ah.. You have learned the difference between a woodworker and a craftsman.
This is a lesson I’ve learned the hard way but it is indeed valuable..
No need to be apologetic.
BT
-- Bruce
16598 posts in 469 days
posted 109 days ago
Sharon I agree with your dovetail repair the best repair for wood is wood. Not fillers or epoxy when the repair is to have a finish.
PurpLev
posted 109 days ago
Thanks everyone for the feedback. I am not apologetic though, I am very pleased with the results of the repair, and with the results of my idea which apparently (and not surprisingly) is not original. like I mentioned – I think knowing how to fix stuff is an important skill, but I also strongly believe that we should aspire to do work that will not require fixing.
and I agree. the best repair for wood is wood, and it’s not hard to do.
