Didn’t have much shoptime lately, which made me try to squeeze every moment I got to try and make the most of it, which lead to rushing, which lead to screw up – but I’ll write more about that in a following installment and leave this one a bit more on the positive side.
Last time I ran into the issue of having a not-square top part to work with. I fixed that by routing the edge at a 0.1 degree angle to straighten the front of the slab and make it parallel to the front 2 legs. I then jointed a strip of maple (2 short pieces) and glued it to the skirt, and took that through the planer to mill it to final size so that it’ll match the main tabletop slab and sit flush with the front legs.
Next I drilled 2 holes in the endcap, counterbored them, and drilled maching holes in the benchtop to take bolts which will secure the endcap to the table and counteract the vise forces when in use. the front of the endcap is not bolted in but is dovetailed into the skirt.
I chose to use a 2 inverted dovetail mainly for design and look – although they have more angled faces that in effect can withstand better pressure – in this case- I don’t think that extra strength is really needed, but I do like the look of it.
to make the tails, I used my bandsaw, and the dovetail jig I made for it based on The Bandsaw Book:
I used the jig because the skirt is 80” long and was hard for me to clamp in a way to allow me to cut those tails by hand square and cleanly.
I then transferred the lines to the endcap, and handcut the sockets. and started chopping off the waste. what I found was an easy way to do so, was to chop the top half of the socket off – staying true to the edge of the small embedded tail. then use the side walls as reference and chop off the extra material from the 2 smaller sockets:
Here is where I started pressing for time, and ran into several issues, one was that I originally had left the endcap oversized in length by an extra 2” so that I can trim it to length, but forgot to do it – so I had to chop 4” deep dovetail socket to accommodate for that (noticed it too late – again). also the endcap grain was running against me, so I had some tearouts in the middle of the socket – no big deal, but when I trimmed the endcap to length (roughly) those tearouts are now visible. I also have an issue with oversized dovetails (only did 2 so far) and find it hard to stay to the lines when the sockets are bigger than the size of the chisel… overlapping those cuts seems to be something I need to work more closely on.
excuses excuses excuses – bottom line, the DT although doing it’s job, leaves quite a bit to be desired when it comes to visual. there are gaps, and the bottom of the socket is being pushed out by the tails…. I was really stressed in time and glued it too soon before taking the time to finesse it some more. I will fill it with some endgrain to minimize the visual, and plane it all to final length, so it will look a bit better. the good thing is, it showed me my weak spots, and what I need to focus on in the future when attempting similar joinery.
EDIT: Here is the Screwup, and the Fix
so this is what the bench looks like:
Another part is (somewhat) behind me (only some light trimming), and next would be the vises to finish this off.
Thanks for reading,
Peace.
10 comments so far
sIKE
home | projects | blog
1094 posts in 647 days
posted 112 days ago
It seems that you have bumped into problems with details! Isn’t that always the case. I look these as opportunities to show your true wood worker skills!
kiwi1969
600 posts in 335 days
posted 112 days ago
Did you assemble your bench inside the mess or did you assemble the mess around your bench?:-) HeHe
16676 posts in 470 days
posted 112 days ago
Hey Sharon
Cool joinery and Jig makes for and outstanding bench great work
PurpLev
2733 posts in 541 days
posted 112 days ago
sIKE- very true. generally speaking- this is not something I would have wanted to post, but would try and hide it… but in the spirit of LJ I figured, others might benefit from knowing they are not the only one to screw up.
kiwi – I just bring all the mess for each picture, then clean it again ;). it’s actually part of my training: step 1. get to the workbench in 1 piece… step 2. woodworking. but seriously – this lumber used to be where the bench is now – so as soon as I’m done with the bench, it’s cleanup time (finally).
Jim – Thanks, but although the tails came out great, the sockets are far from it… if I’m brave enough, I’ll post it soon (hopefully I can also get an “after” shot of a cleaned up and fixed solution)
25797 posts in 1293 days
posted 112 days ago
Looking great Sharon. Nice recovery.
Don K.
1095 posts in 219 days
posted 112 days ago
Still enjoying the update Sharon….the bench is turning out great !!!
-- Don S.E. OK
jlsmith5963
180 posts in 241 days
posted 112 days ago
Mess? What mess? I hate it when I can’t understand what everyone is talking about in these blogs.
-- criticism: the art of analyzing and evaluating the quality of a artistic work...
Gary Fixler
646 posts in 274 days
posted 111 days ago
Those are some pretty fancy dovetails. I like the multiple lengths.
I see you have puzzle mats. I had those, too. They’re stacked up on a trash can outside (not trash, though). They were just too much hassle. So much work to sweep and vacuum around them, or to roll tools. Are you still enjoying them, or are they pulled up because you’ve had enough, too?
-- Gary, Los Angeles, video game animator
PurpLev
posted 111 days ago
Gary – like you’ve experienced – these interlocking mats are hard to vacuum, and roll tools/others on top. I do however place them strategically in front of the workbench, or other work areas where I’ll be standing for a while. I keep them in small parts (1-3 interlocks) so that worst case, they can be picked up and put aside. I also use them to elevate things off of the concrete floors (lumber) – not sure if it really helps much, but for my piece of mind thats good enough.
they used to carry them in Costco Burbank. I picked 1 pack, and after that I never saw it again there… when we moved to Boston, I saw that Costco here still carries it, and was so excited I picked up 5 packs… a bit much, but I use it around for different things. also used it on the hardwood floors when our daughter was learning to walk to cushion the falls..
3710 posts in 872 days
posted 111 days ago
Hi Sharon;
Great band saw jig.
This bench will be a masterpiece.
