I just found a couple of cedar burls that have been drying in a barn for at least 50 years, one has only a couple of checks, the other has a few, the biger one is 27×17x10, the other is around 17×24x12 Im trying to figure out how to cut this stuff as it won’t fit in the band saw, Any suggestions?
-- Life is to short to own an ugly boat.
8 comments so far
frank
home | projects | blog
1503 posts in 1099 days
posted 611 days ago
Hello Pete_Jude;
—-and welcome to the world of blogging and wood questions….
Great find on the burls there, but without any photos it’s kind of hard to see what your talking about….so why not include some photos and then we, can give you, our many opinions. Actually I just want to ‘slabber’ some over your great find….and,
Thank you.
GODSPEED,
Frank
-- --frank, NH, http://frank.wordpress.com/
rikkor
11335 posts in 767 days
posted 610 days ago
Great find. Good luck with it, it’s a treasure.
Dooley
75 posts in 615 days
posted 610 days ago
sounds like you could get away with using a hand saw, yep I said it.
-- Dooley, Wheat Ridge, Colorado http://www.facebook.com/joshua.whaley
jeffthewoodwacker
486 posts in 697 days
posted 610 days ago
As much as I would hate to say this you may have to crank up the chainsaw.
-- Those that say it can't be done should not interrupt those who are doing it.
14914 posts in 744 days
posted 610 days ago
It depends what you want to use it for. I thing Jeff has a good option but there is always someone that will have a bandsaw. you could ask any Jocks nearby to help out. With a treasure like that I would think pretty hard about what the end result would be. Lots of luck.
Pete_Jud
116 posts in 646 days
posted 610 days ago
http://offthegridlights.com/burl/burl4.JPG
http://offthegridlights.com/burl/burl2.JPG
http://offthegridlights.com/burl/burl3.JPG
http://offthegridlights.com/burl/burl1.JPG
Pete_Jud
posted 610 days ago
I just added pictures of the burls, and I still have no idea what to make, Im thinking about sliceing the first couple of 2 inch thick pieces out of the faces and turning bowls out of the remanders. A friend sugested a bow saw at less than 10 bucks for the sliceing.
Any input is valued
Dorje
1767 posts in 890 days
posted 610 days ago
Just noticed you’re from Washington!
I’m not sure how I’d cut them…I’d probably wait til I had the inspiration of what I wanted to make out of them beforehand. But, that may take another fifty years…
That said, it does look like you have the makings for a couple of small live edge table tops if you slab off the top faces of each of the burls. You could also make some interesting door panels out of them (for small cases), by cutting thick enough to resaw for bookmatched pieces. You could use the slabs for a series of drawer faces that would have a contiguous grain pattern. Possibilities are endless. I like your idea of saving some stock for bowls.
I don’t think a bow saw’s gonna do it. You’d run into the frame of the saw and couldn’t get through the entire width. Though you could try coming from both sides and you might just be able to do it, depending upon the size of the saw you use!
Good luck – let us know what you end up doing!
Also – if you put exclamation points just before and just after your hyperlinks for your pics, they should show up in the post…you may have to make your pics a touch smaller though, so they fit in the post window.
