Noob On The Loose!!! #1: Noob On The Loose!!!
Blog entry by Paddle_Tail posted 02-13-2014 03:53 AM 851 reads 0 times favorited 4 comments Add to Favorites Watch
no previous part Part 1 of Noob On The Loose!!! series Part 2: More of what I have learned along the way. »
Things that I have learned as of right now
1. Glue is your friend. Use It!
2. Always run your wood thru a jointer, sander, or planer before a glue up.
3. Make sure the table is level and straight
4. Take your time don’t rush a good thing ever!!!
5. Push yourself to another level, but don’t bite off more than you can chew.
-- Wayland,Arkansas,~Chance Favors The Prepared Mind~
4 comments so far
View Thuzmund's profile
Thuzmund
148 posts in 1655 days
#1 posted 02-13-2014 05:33 AM
I would suggest you buy a decent square or two. The handiest tool ever invented!
-- Here to learn
Thuzmund
#2 posted 02-13-2014 05:35 AM
Holy cow, after seeing your Argyle cutting tray I officially rescind my comment. :) You don’t need any of my help!! Amazing stuff—something for me to shoot for!
-- Here to learn
View Jake's profile
Jake
850 posts in 1657 days
#3 posted 02-13-2014 05:45 AM
I always bite off more than I can chew and then munch on that bad boy for extended periods of time… :D
-- Measure twice, cut once, cut again for good measure.
View Paddle_Tail's profile
Paddle_Tail
24 posts in 1597 days
#4 posted 02-13-2014 05:58 AM
@Jake I have with the up coming project but when im done i plan to chew on it for a long period of time then use its splinters to pick it out of my teeth
@thuzmund that argyle was my second one i had ever done not to toot my own horn but d@mn proud of that one
