At least I believe we have identified it.
Shopsmiths have a very active user group forum, and the members there have helped me identify which model I have.
It seems that my SS is a “Goldie” MK 5 (not MK V) model 500, manufactured somewhere from 1960 to 1963 by Magna Corporation before they went out of business in 1964. Shopsmith Inc. (founded in 1972) still supports the Magna machines.
It seems that the clincher in identifying it was this warning label riveted onto the headstock casting – apparently all of the other models have stick-on labels.
The machine has obviously undergone some not too clever repair and maintenance in it’s long career, evidenced by this make-shift power switch.
This machine seems to be almost as old as me, and older than many LJ’s. I just wish I could renovate myself with some electrolysis, sand paper, paint and wax.
The reference to electrolysis is a method employed by several SS refurbishers to remove rust. I know many LJ’s refurbish old tools and machines, but I haven’t seen mention of electrolysis as a rust remover. I’ll post that process and the results when I do it – hopefully it will help someone restore a plane or two.
5 comments so far
whitedog
home | projects | blog
649 posts in 1629 days
#1 posted 1184 days ago
that power switch isn’t stock ? I’m surprised.
-- Paul , Calfornia
David Craig
2127 posts in 1281 days
#2 posted 1184 days ago
Looking forward to seeing the progress. Be careful when using the switch, it might activate your neighbor’s garage door opener…
David
ajb
29 posts in 1234 days
#3 posted 1184 days ago
good luck on this one I am in the middle of a refurb job myself on a radial arm saw about halfway through I had wished i had just left it alone but now that it is almost done, I* have realized how much i have probably learned about the machinei wouldn’t have know about before. Hope you have a lot of fun with this.
OutPutter
1194 posts in 2162 days
#4 posted 1183 days ago
You might try looking through the posts about plane restoration for some electrolysis examples. I’m sure I saw one just recently.
-- Jim
John Stegall
355 posts in 1689 days
#5 posted 1182 days ago
I am mainly posting so that I can keep up with this restoration. I owned a Mark V from about 1980 until 1994 when I sold it to make a cross-country move. I used it mainly as a lathe and horizontal boring machine (not for cutting mortises).
-- jstegall
