Rescued Wood #7: Yellowwood Slabbed and Stickered for Drying
Blog entry by PG_Zac posted 01-08-2010 10:36 AM 2459 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 6: Yellowwood Slabbed Part 7 of Rescued Wood series Part 8: I've got some work to do Tomorrow »
Do you remember this picture from Rescued Wood #4 ?
Well, I’ve slabbed it and stacked it for drying.
I cut the boards 30mm thick so that I can have wide boards a good 1” available after final milling. This post is about my stacking method, but I can’t resist showing off some of the beauty exposed by the milling.
First Cut
Tornado Flame grain
To give you a good size reference
After slabbing the whole lot, I put them back together in sequence (including one of the partial-round offcuts) and mark them with a triangle and a board number. I also record the fell date, slab date and species on the painted ends.
Then I stack them in sequence with 3/4” stickers for air flow. In this case, my stickers are skinny parquet blockettes destined for the dump.
I place one of the partial-round offcuts on top and then bind the whole log together with ratchet straps.
Strapping them together like this ensures good stability while drying – any tendency to warp is counteracted by the rest of the log.
Marking and stacking like this makes it very easy to find book matched pairs long after the wood is dried and stacked on lumber racks.
I have 10 boards, 8 of which are wider than 30cm (24”) at the narrow end.
Edit
I goofed on the measurements – All of boards are wider than 30cm (which is 12” not 24”) , and 8 of them are wider than 45 cm (18”)
I’ve slabbed many logs, but I am still amazed at the beauty that I find inside the log every time I lift off the first cut.
5 comments so far
View ratchet's profile
ratchet
1391 posts in 3662 days
#1 posted 01-08-2010 03:18 PM
Man, I like that shot of the cut log stickered and bound.
Thx for sharing.
View David Craig's profile
David Craig
2137 posts in 2984 days
#2 posted 01-08-2010 03:21 PM
Very well documented post on your process, thank you for your time and trouble. Some very good info for anyone who would like to know how to mill their own lumber. Looks like you will have some beautiful wood to work with.
David
View PurpLev's profile
PurpLev
8534 posts in 3524 days
#3 posted 01-08-2010 04:20 PM
these are a beauty. will make for some great furniture
View woodsmithshop's profile
woodsmithshop
1296 posts in 3421 days
#4 posted 01-08-2010 05:41 PM
great idea, using the strap clamps, should work as well if not better than weights.
-- Smitty!!!
View Cher's profile
Cher
954 posts in 2969 days
#5 posted 01-09-2010 08:04 PM
I can’t wait to see what you do with that ‘pot of gold’
