Parquet Blocks Veneer - Any Ideas?
Blog entry by PG_Zac posted 12-10-2009 10:41 PM 1438 reads 0 times favorited 4 comments Add to Favorites Watch
Further to my post on Parquet Floor Blocks, I knew I had to test my veneer cutting skills before (possibly) wasting this beauty.
So last night I cleaned my Wood Slicer bandsaw blade with oven cleaner, and tonight I setup the bandsaw, adjusted for the blade drift as best I could (I have never before been completely successful), and ran a few floor blocks through the saw.
Firstly, I was shocked that my drift settings were spot on (woo-hoo) and the block sliced like a dream.
Secondly, I cut my third block into slices only 1.3 mm thick.
Now I’m looking for ideas on how to use these 3” x 6” veneer sheets.
Any suggestions?
4 comments so far
View PurpLev's profile
PurpLev
8535 posts in 3646 days
#1 posted 12-11-2009 03:18 AM
are these really 3”x6” ?!? the photo makes it look bigger- more like 6”x12” in which case it would allow for more applications for those (door panels, drawer fronts, etc), but at 3”x6” it’s quite small to bother with veneering anything in my opinion.
View scrappy's profile
scrappy
3507 posts in 3428 days
#2 posted 12-11-2009 07:44 AM
Quarter panel bookmatch a box top? That would make them 6×12 could be a jewelry box front door or sides.
JMHO
Scrappy
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
View PG_Zac's profile
PG_Zac
368 posts in 3386 days
#3 posted 12-11-2009 08:58 AM
You’re correct Sharon – I messed up with the size.
They are 3”x9”.
I’ll probably resaw most of the blocks in half for small boxes, and veneer cut any specials I find (like the top picture)
That’s about all I could think of Scrappy. You seem to favour scrap projects – any other ideas?
scrappy
#4 posted 12-14-2009 12:32 AM
I think the boxes idea is pretty good. Using panels for door fronts on jewelry cabinets, or try your hand at inlay. It could be a knew passion.
When doing other things, it is nice to add a veneer strip as an accent piece. either in segmented turnings or in an angle cut across a box top.
Scan through the projects and I am sure you will get plenty of ideas.
Keep us posted.
Scrappy
