Tool thoughts #5: First turning on my lathe
Blog entry by NedB posted 452 days ago 205 reads 0 times favorited 6 comments Add to Favorites Watch
« Part 4: Lights, Camera, Bench! Part 5 of Tool thoughts series Part 6: Organizing continues »
I glued a sacrificial block onto a chunk of Mahagony I found in my storage unit the day before yesterday. Last night I broke out the turning tools after cobbling together a temporary lathe stand… I actually used my miter stand:
temp lathe stand
One thing I found, was that I want to lower the lathe a couple more inches,
Ilathe and faxe shield
I will need to get shorter bolts, which will help, I wound up putting the 2×8 I bolted the lathe to on top of two 2×4’s, which really raised things up higher than I liked.
I have a basic set of HSS chisels spindle tools for the most part, certainly the gouge I was using wasn’t set up for bowl turning… chisel
I got some help from Adam, moving this into the shop as well…
bandsaw
let me tell you, that basic little bandsaw (HF with a grizzly riser kit) has an incredibly overbuilt base.I think my friend who built it used 4 sheets of MDF! would you believe two? either way, it isn’t going ANywhere without major thought going into the parking spot. I picked it up used earlier this year, and last night was the first time I got it tuned up and working. It’s got a decent blade for general shop use, I won’t try resawing until I can pick up a couple of blades from Suffolk. I also unearthed my grinder. It’s a no-name 6” bench grinder, just a generic wheel and wire brush which I was given last spring. Who am I to say ‘no’ to a free tool?
grin der
-- Ned - 2B1ASK1 http://nedswoodshop.blogspot.com
6 comments so far
Beginningwoodworker
4123 posts in 566 days
posted 451 days ago
Nice set up Ned,
-- CJIII Future cabinetmaker
View trifern's profile
trifern
7894 posts in 660 days
posted 451 days ago
The recommended height for lathes is so the centerline of the headstock is the same as distance from the floor to your elbow.
View Tony's profile
Tony
812 posts in 923 days
posted 451 days ago
Instead of lowering the lathe, why not just make a small platform to stand on?
View NedB's profile
NedB
257 posts in 458 days
posted 451 days ago
Thanks CJ!
Trifern, that’s about where I want to put it, as it sat in the photo there it was just above that level.
Tony, just a matter of an inch or two, and that was Not my permanent setup, just wanted to make sure that the lathe worked. I’ve since stowed it under a bench so I can finish moving my stuff into the shop.
View Mark Shymanski's profile
Mark Shymanski
1555 posts in 605 days
posted 451 days ago
I see your bench grinder has the same mounts as many of my tools do when they are not hiding on a shelf somewhere :-)
View NedB's profile
NedB
posted 450 days ago
yup, it worked just fine with those mounts.
