Tool thoughts #3: Pondering the next Tool Purchase
Blog entry by NedB posted 455 days ago 221 reads 0 times favorited 10 comments Add to Favorites Watch
« Part 2: Doors! Part 3 of Tool thoughts series Part 4: Lights, Camera, Bench! »
I’m taking a few minutes during my lunch hour to think about my next tool purchase.
I have a pretty good core set of tools, but there are a few items which I’ve used in the past, which were my mentor John’s tools. One of those was a dado stack, and I’m debating about whether or not to bump that up the priority list of tools to buy.
Thinking of what a stack does might help.
The primary function of course is to make a Dado. I can do that with multiple passes of my normal blade, bumping the fence over repeatedly, not my favorite method, but if I have to do it, I can. And I have done precisely that most recently to hog out the notches for perlins on my shop trusses. Turns out that I could have skipped that step, as I eventually chose a metal roof, which nescessitated nailers all the way across the roof. live and learn.
It also can be used to make a rabbet, I can and have made rabbets via the TS method, make one cut, rotate workpiece, reset blade height etc…
I also can use my router with fence to do that, or get off my duff and make a router table and so forth to do the same thing. This might actually be the preferred method for awhile, since I have a router, need to make a table, and the costs involved are less than the dado stack.
Thanks for reading, we’ll see what I wind up doing in the long run.
-- Ned - 2B1ASK1 http://nedswoodshop.blogspot.com
10 comments so far
View SCOTSMAN's profile
SCOTSMAN
2238 posts in 479 days
posted 455 days ago
Here in Europe dado blades are not allowed unless you work by yourself and take your own chances. In other words not for employees.All of our saws are fitted with a short spindle so as not to allow the fitting of Dado blades people sometimes get around it with radial arm saws etc.The authorities reckon we will damage ourself when we remove the guards.Anyway I make single tooth cuts normally with my radial arm saw and it is slightly laborious but workable.Kindest regards and good luck with your decision.Alistair
View Dusty56's profile
Dusty56
3460 posts in 582 days
posted 455 days ago
welll , I invested in a top of the line dado set 4 years ago , and it hasn’t even seen the arbor on my saw yet : ( Heck , I can’t even remember what the brand name is right now …..on the other hand , I built and use my router table for just about every project that I have made to date : ) Also with a good straight edge , I have made numerous dadoes with my router and rabbets all the time . Personally , my next big purchase will be an 8” jointer with a spiral head !!! Have fun and be safe !
View NedB's profile
NedB
257 posts in 459 days
posted 455 days ago
Alistair, Strictly a hobby shop over here across the pond. Just me and the tools, unless one of my sons decides to hang out in the shop with me.
Dusty, That’s fuel for saving my money, thanks for the reinforcement. My next ‘big’ purchase is going to be wiring and a sub-panel. After that, a 6” jointer will be on my short list, I have a planer, but need a jointer in the long run.
View bbqking's profile
bbqking
332 posts in 617 days
posted 455 days ago
I bought a expensive dado set 2 years ago. It is still exactly where I placed it after purchase. Never been used. Same exact reason as Dusty56. My next big purchase is a bandsaw upgrade. Still shopping.
-- bbqKing, Lawrenceville
View ajosephg's profile
ajosephg
441 posts in 455 days
posted 455 days ago
I hardly ever use my dado set. I built a jig for my router that basically clamps over the board to be dadoed with the guide on the jig aligned appropriately. The guide is designed so that the width of the dado can be precisely adjusted without changing the bit diameter. It also works great for making precisely aligned dadoes in 2 boards, as you can clamp both boards in the jig and and cut both in one pass. I got the plans out of a book many years ago, and I have seen similar jigs on the net. If you are interested, let me know and I will take a picture of mine and post it.
Another advantage is that it easier to move a “small” router across a board, than to move a “large” board across a tool.
-- Joe
View NedB's profile
NedB
posted 455 days ago
Joe, I have a pretty good jig in mind, from Bill Hylton’s ‘Woodworking with the router’ book, as you say, the router is a lot easier to move and control vs the large workpiece.
ajosephg
posted 455 days ago
Good deal. The key feature on mine is that the width of “track” that the router goes down and back on is adjustable. For example if you want to cut a 3/4” dado, and you are going to use a 1/2” bit and the base of the router is 6” in diameter, you would adjust the track so that it is 6 1/4” wide.
-- Joe
View CelticDreamer's profile
CelticDreamer
35 posts in 548 days
posted 454 days ago
I just blew my tool budget all to hell by purchasing a Powermatic 8” jointer. I was considering getting a high end stack dado as my next purchase, but after reading Dusty56 and bbqking, I have to wonder if that’s the way to go. I have to ask what was you reasoning for buying the blade? Also, if it’s going to just sit there are you going to sell it cheaply? <g>
-- last night I played a blank tape at full volume - the mime next door went nuts!
View John Gray's profile (online now)
John Gray
1753 posts in 779 days
posted 454 days ago
From my experiences with a stacked dado set I’m staying with my router and router table.
View sIKE's profile
sIKE
1094 posts in 648 days
posted 454 days ago
If you do a lot of case work with dadoes/rabbits, or half lap work then a dado set is great asset but if you don’t then it will probably gather dust.
My Miter bench and associated cabinets are all built using a stacked dado set the nice thing is you can use shims to get the exact width of your plygoods and only run the boards through once. If you do half laps be prepared for the sawdust!
