Hal Taylor Rocking Chair #7: Front leg joints and arms attached
Blog entry by NY_Rocking_Chairs posted 1473 days ago 3211 reads 2 times favorited 5 comments Add to Favorites Watch
« Part 6: Back and Front Legs Part 7 of Hal Taylor Rocking Chair series Part 8: Week 6 - Back Braces and Head Rest »
Ok. So on Friday I glued the four legs to the seat. Now it is time to clean up all the joints and make them look great.
So after glue up, our front leg to seat joint looks like:
Front Leg Joint Top
Front Leg Glued
So I break out my trusty Lancelot carving disc on the right angle grinder (see seat carving) and ever so gently get rid of the excess material, not trying to get perfect, just close.
Front Leg Joint Carved
On the top and bottom of the seat where the leg needs to flow into the seat I use a spindle sander on the power-drill to get close and then finished up all aspect of the joint with the ROS:
Front Leg Joint finished
The same treatment is applied to the back leg joints. The sides and back of the seat are also sanded flush with the back legs so everything is smooth and flowing.
The arms are attached next. This is a deviation from Hal’s order who attaches the headrest next. I like to attach the arms because shaping the arm-to-leg joints is much more easily accomplished without back-braces in the way.
Arms Attached
-- Rich, WNY, www.nyrockingchairs.com
5 comments so far
View Julian's profile
Julian
880 posts in 1723 days
#1 posted 1473 days ago
Looking good! Thanks for the step by step with pictures.
-- Julian, Park Forest, IL
89114 posts in 1774 days
#2 posted 1473 days ago
Looking good nice photo work up.
View stefang's profile
stefang
9727 posts in 1531 days
#3 posted 1472 days ago
Really interesting and informative.
-- Mike, American in Norway
View Mike Gager's profile
Mike Gager
616 posts in 1464 days
#4 posted 1355 days ago
not sure youll see this since this post is older, but how are the arms attached to the legs? i would assume maybe screws but i dont see any holes or plugs in the pictures
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
485 posts in 1794 days
#5 posted 1343 days ago
Where the arms meet the back legs, 4” screws are driven through and then plugged. Where the arms meet the front legs, there are 1 1/2” screws driven through and plugged. Also, copious amounts of glue are applied. I just received the new book and the new design no longer puts screws in the front legs but some adder pieces are screwed to the legs and these adder pieces have a lot more surface area that the arms glue to.
