Hello again…
Due to backing up septic tanks and clogged pipes I was not able to get into the shop until Saturday. I accomplished everything on my list for the week and will continue Sunday with more sanding of the seat, leg shaping and then glue the legs and seat together by mid-week next week.
For now, on to today’s progress:
Started out with a 1 1/2 hour sanding marathon. 45 minutes per arm:
Here is a picture of the 1st arm sanded next to the arm that has not been touched since it came off the table saw and band saw…
The next picture is 45 minutes later with both arms sanded. I start with 60-grit, go to 120, 220, 320, 400 and then finished up with a 500-grit abralon pad. The pads are pricey at $65 per box of 10, but well worth it, this year I even forked out more to get some 1000-grit pads, not sure it was worth it, not a huge noticeable difference between sanding to 1000 versus ending at 500.
From here I went to work on the leg joints. As you recall from working on the seat, we cut a bunch of notches, rabbits and such. To get the legs to fit these joints we start out by marking the legs for where they need to match up to the seat. Then using the table saw, we cut notches in three sides of the front leg blanks. The leg blanks were dimensioned to fit the seat gap perfectly before-hand though.
The back legs also get marked and the notches cut on the table saw. Trial fitting to the seat joints are key during the notching of both the front and back legs so that you don’t remove too much material and you get a nice, tight fit.
After I am satisfied with my notches I use a round-over bit which is the same radius as the rabbit bit we used on the seat. This gives us the nice curve which is identical to the curve on the seat. Here is a picture of all four legs after being put through the router:
Here is the seat sitting on a raised toolbox with the legs all in a dry-fit:
The joints are tight enough that is takes some persuasion with the mallet to get them tight, but not too tight that you have to worry about splitting wood. With the legs in position I mark the legs where they hit the top and bottom of the seat, this gives us a guide for when we final shape the legs. I also mark the seat where the back legs hit it so I can mark and band-saw both the sides and back of the seat with a nice curve. I like to use the rocker-taper template for marking the seat, it is a nice curve and I know each side will be identical. With the sides and back of the seat band-sawn I will now proceed to sand the heck out of the seat all the way through 500-grit.
-- Rich, WNY, www.nyrockingchairs.com
7 comments so far
home | projects | blog
17140 posts in 476 days
posted 182 days ago
Looks like great progress and beautiful wood, looking forward to more photos.
SCOTSMAN
2244 posts in 484 days
posted 182 days ago
Awesome and also really lovely wood too well done sir Alistair
Skarp
180 posts in 225 days
posted 182 days ago
Looking good. Have you used cabinet scrapers before? My arch-nemesis is sandpaper. Scrapers save SO much time compared to sanding. Look forward to seeing the finished piece.
-- Ooo, er.
NY_Rocking_Chairs
435 posts in 496 days
posted 182 days ago
The photos were just accidently deleted, give me 10 minutes and they will be back up…
All fixed again, web site has been revamped and recovered…
stanley2
278 posts in 694 days
posted 181 days ago
Rich, I’m enjoying your blog especially with Sam’s passing on so recently. I’m curious about your sanding schedule to 500 grit. Is this Hal Taylor’s recommendation? Normally, we sand to 180/220 to allow adequate finish penetration and sand the finish itself to the higher grits.
-- Phil in British Columbia
7356 posts in 1145 days
posted 181 days ago
Looks likes its going to be a beauty.
-- Mike. mwurm13@yahoo.com
NY_Rocking_Chairs
posted 181 days ago
The sanding is Hal’s recommendation. The finish used is Deft Danish oil which is a penetrating oil and is not really sand-able. I follow Hal’s advice and sand the wood to 500 before applying the finish. The finish application is also Hal’s recommendation which is to apply liberal amounts with a paper-towel and keep the wood looking “wet” for about 10-15 minutes, then wipe dry with new paper towels. Let the piece rest for about a week and then do a quick sand with a 500-grit pad and then a quick wipe wet with the oil and immediately wipe dry.
