I'm looking for an answer to my problem
Blog entry by NH_Hermit posted 11-15-2014 05:31 PM 1309 reads 0 times favorited 11 comments Add to Favorites Watch
I need some help.
I made my wife a frame for her embroidery that she can use while sitting on the couch. Right now, I have it designed so she can position the working frame in any direction her pea pickin’ heart desires. The only problem she has is the position of the arms will not hold when she puts some weight on the frame, no matter how much she tightens the bolts.
I think I know the solution, but don’t know what to call it or where to find it. I think I want something like an unthreaded “T” nut (or washer) that has a grooved flange that I can embed into each opposing arm. Does this question make any sense?
I’ve added a couple of photos as further explanation.
Thanks in advance, John
-- John from Hampstead
11 comments so far
View Rob's profile
Rob
704 posts in 3096 days
#1 posted 11-15-2014 05:58 PM
How about roughing up the mating surfaces of the joints? Just inserting a roughed up metal washer or rubber washer between the two pieces of wood in a joint might do the trick. Or modify the joints so they have interlocking positive stops every few degrees of rotation. You could also replace the knobs with cam levers so they’re easy to get really tight.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View Grumpymike's profile
Grumpymike
2260 posts in 2340 days
#2 posted 11-15-2014 06:02 PM
Yep, I think you have answered your own question … I had a “swing arm lamp” that wouldn’t stay put … found some washer looking things that had grooves on one side … epoxied them to each arm with the grooves out and inserted a longer screw … they “lock” together and stay.
Now for the $64000 question, ... what are they called??? in the 60’s they would have been ‘Groovy washers’.
I got them years ago at Tacoma Screw Products … Mc Feely’s carries lots of fasteners & stuff, 1-8oo 443-7937
Good luck and let us know how your search went.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
View JoeinGa's profile
JoeinGa
7736 posts in 2032 days
#3 posted 11-15-2014 06:03 PM
rubber washers between any (or all) of the sliding surfaces might make them stick better.
Grumpymike
#4 posted 11-15-2014 06:07 PM
Go to Tacoma Screw Products on line and look up Nord-Lock washers … Page 4 in the washer section
View TheDane's profile
TheDane
5441 posts in 3688 days
#5 posted 11-15-2014 06:57 PM
Nord-Lock washers are also available from Fastenal and Grainger
View NH_Hermit's profile
NH_Hermit
394 posts in 3121 days
#6 posted 11-15-2014 08:08 PM
Great!!! Nord-Lock looks like the answer – but I wish they were called “Groovy washers”
Thanks a bunch.
Rubber washers might also work and be a bit cheaper.
View NormG's profile
NormG
6138 posts in 3029 days
#7 posted 11-15-2014 10:04 PM
Grooved washes would be best
-- Norman - I never never make a mistake, I just change the design.
View stefang's profile
stefang
15881 posts in 3359 days
#8 posted 11-15-2014 10:05 PM
Hi John. I was thinking that you could just hold the arms up for her while she works. I’m sure she would appreciate that. Otherwise the locking washers sounds like the best solution as your wife could tight them securely without using undue force.
View Tim Dahn's profile
Tim Dahn
1567 posts in 3590 days
#9 posted 11-15-2014 10:40 PM
A leather washer may work also
NH_Hermit
#10 posted 11-16-2014 12:44 PM
Mike, I told my wife about your suggestion. She liked it a lot – a tad more than I did. I’m trying the Nord-lock washers. But I do like the beard. Getting ready for the Norwegian winter?
Tim. Leather washers are an idea I had not thought of.
stefang
#11 posted 11-16-2014 06:58 PM
Originally I thought it would hide my ugly face, but it just made me more ugly! A lot of my projects work out that way.
