1956 DeWalt MBF 9" Radial Arm Saw #4: R-A-S-p-e-c-t: Mister Sawdust ? Your table is ready
Blog entry by NBeener posted 02-12-2011 07:56 PM 8173 reads 0 times favorited 9 comments Add to Favorites Watch
« Part 3: Parts ... is parts ! Part 4 of 1956 DeWalt MBF 9" Radial Arm Saw series Part 5: Just getting my bearings »
Forgot to add this one to the blog series….
http://lumberjocks.com/topics/24247
As you were :-)
-- -- Neil
9 comments so far
Beginningwoodworker
13347 posts in 3542 days
#1 posted 02-12-2011 08:11 PM
Thats ok, Neil. I will get my RAS Monday!
View NBeener's profile
NBeener
4816 posts in 3043 days
#2 posted 02-12-2011 08:17 PM
Can’t wait for the pictures, Charles !!
By the way ….. I wanted to get a “before and after” to see how much difference it makes, replacing my motor bearings.
With NOTHING on the arbor … the motor spins down to a full stop in 1.25 seconds … from the time I flip the switch OFF.
Once I replace the bearings, I’ll do the timing again.
May want to check yours, because … even though they’re different, it might give you an idea of what kind of shape your bearings are in !
-- -- Neil
Beginningwoodworker
#3 posted 02-12-2011 08:39 PM
Ok I will, Neil.
View HokieMojo's profile
HokieMojo
2104 posts in 3597 days
#4 posted 02-12-2011 09:15 PM
mine spins for a while after shut off. Like probably 10 seconds. I think that might actually be a bad thing though. I think it means there isn’t enough grease. I’ll be really interested to see how long yours spins after replacing the bearings. My guess is that anything more OR less might mean that things aren’t working quite right.
1.25 seconds does seem pretty short (but I don’t know for sure) for a saw that doesn’t have an electronic break. I think your choice to change the bearings is probably smart.
View Dennisgrosen's profile
Dennisgrosen
10876 posts in 2984 days
#5 posted 02-12-2011 10:11 PM
great looking table Neil :-)
take care
Dennis
NBeener
#6 posted 02-12-2011 11:53 PM
HokieMojo: is that with nothing on the arbor ???
Hm. Interesting.
Rather than the electronic “dynamic” brake that a few of these DID have, mine has what’s known as the “viscosity broke down, and metal shavings turned the original grease into an abrasive sludge” brake.
Yeah. You’re jealous. I know ;-)
I did some actual woodworking, today, instead of working on the saw (what WAS I thinking ?!?), but … probably Tuesday, I’ll crack ‘er open, and get to changing out all the bearings.
Will report back.
If you know how to service bearings (and if they ARE serviceable), it’s NOT difficult to rebuild bearings, clean up everything, and either re-install the existing balls, with new grease, or—safer bet—replace the balls. As a home bike wrench, I actually have a few different sizes. When I bought them, I bought tighter tolerances than OEM.
So … you COULD go that way, if you were so inclined.
Thanks much, Dennis ! I’m probably only a month away from cutting something (other than myself), at the pace I move :-)
-- -- Neil
HokieMojo
#7 posted 02-13-2011 03:24 AM
I must have read too fast. That was with a blade. I couldn’t tell you about without because my saw didn’t come with a wrench. The only way I was able to get the blade off was to put the blade in a clamp while the motor was removed from the carriage and remove the arbor nut (I did that today). I don’t know how I’m going to do the blade changes in the future, but I’ve been researching that as well. I hear bike wrenches might be a good solution.
NBeener
#8 posted 02-13-2011 05:09 AM
View dbhost's profile
dbhost
5686 posts in 3101 days
#9 posted 02-13-2011 09:26 AM
How were we?
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
