This looks like a fun project. The idea is from American Woodworker.
To make it more chip carve-able, I was thinking about not drilling the large holes in all the squares and then chip carving those surfaces. That along with the cut off corners would make a really cool piece.
What do you think?
Step-by-step instructions are found here –
http://americanwoodworker.com/blogs/projects/archive/2012/01/03/ws-wiffle-ball.aspx?utm_source=AWNL&utm_medium=email&utm_campaign=AWNL_20120105
-- Marty, https://www.MyChipCarving.com, 866-444-6996
4 comments so far
home | projects | blog
87068 posts in 1745 days
#1 posted 501 days ago
A very interesting project and a good link.
leanne
45 posts in 580 days
#2 posted 501 days ago
go for it. don’t forget to post so we can see it.have fun :)
-- Leanne, Australia, http://www.sawdustartonline.com
Woodbutcher3
361 posts in 1055 days
#3 posted 500 days ago
If you make a small one, carve it, then build a larger one around it, that would be cool, too.
thanks for the link!
-- Rod ~ There's never enough time to finish a project, but there's always time to start another one.
MyChipCarving
358 posts in 1293 days
#4 posted 499 days ago
Hi Rod, build a larger one around it
I really like the extra twist you added to this project.
I’ll have to be careful when cutting off the corners on the large outside cube so I wouldn’t cut into the inner cube. The first corner cut would be the hardest cuz you couldn’t see inside.
Any thoughts on how to do this?
