I know that drawing and working on patterns is not enjoyable for many chip carvers.
With that in mind, we will start carving tomorrow.
I’d still like to encourage many of you to give pattern development a try.
I’ll provide some patterns for you to carve. Adding your patterns to the mix will give our finished project more variety. Also, there’s a great sense of satisfaction knowing that the pattern you are carving is one that you came up with on your own.
Here’s an example of one pattern that I’ll provide you and what I did to make it chip carveable.
The grape basket quilt pattern is one that I’ve seen quite a few times.
I started with that pattern, sized it to fit our small square (3.25×3.25” carving area), and then divided it into smaller three-corner chips (triangles). The dots indicate the very bottom of the chip.
Below are a four quilt squares to help you get started. You can adapt and divide the shapes to see what you come up with. When developing a pattern for the large square (5.25×5.25 carving area) you can use four quilt squares in the space to make the size of the chips more manageable.
Marty Leenhouts
https://www.mychipcarving.com Chip Carving
866-444-6996
-- Marty, https://www.MyChipCarving.com, 866-444-6996
13 comments so far
woundedthumb
home | projects | blog
6 posts in 832 days
#1 posted 828 days ago
that helps alot, sometime ago I got a copy of George Bains CELTIC ART< The Method of Construction 1951,1973. I’d like to try to include s psrt of the page attached, if I would not be jumping into to deep water. This book is great I got it when I started teaching (subbing) and used it and an Escher book a great deal.
Thanks again for everything
lew
-- lew (woundedthumb) Pennsylvania, http://woodworkerwoundedthumb.com
helluvawreck
10919 posts in 1064 days
#2 posted 827 days ago
Marty, I did this one a while ago. Will this work ok?
MyChipCarving
358 posts in 1322 days
#3 posted 827 days ago
Yes! That pattern will work fine. Good job getting this pattern ready to go!
Cubie
16 posts in 834 days
#4 posted 827 days ago
Marty,
Here is my first attempt at a pattern. Only the left quarter is finished, I will repeat the pattern in the other three quarters. I’m not sure how this will look carved out so I’ll probably carve a test quarter on a practice board first to see if I like it.
-- Cubie
Merrill
9 posts in 837 days
#5 posted 827 days ago
Has anyone used “tessellations” as a source for patterns? A Google of the word will given you all you ever wanted to know about the math concept. Here is a example—Is something like this workable for chip carving?
-- Merrill, Cody, Wyoming
MyChipCarving
#6 posted 827 days ago
Cubie, good pattern development and good idea to practice first on another board before carving the ‘real McCoy’. I like what I see!
philphoto
8 posts in 1254 days
#7 posted 825 days ago
Marty:
I must be blind or ?? I can’t seem to find the grid size you are working with. I work with graph paper or Corel Draw and I need the grid size to make sure the math is working, and also to have the right size chip. I think. Am I missing something?
Phil
MyChipCarving
#8 posted 825 days ago
Hi Phil,
Start with a 4mm grid when you are first starting out.
I’ll demonstrate this in the next lesson, due out any day now.
4mm is a nice size to begin with.
The patterns you see in this lesson are larger than 4mm. I’ll be providing these patterns for you so there’s no need to draw them yourself.
philphoto
#9 posted 825 days ago
Thanks, I thought 4mm was the grid size but some of the patterns I was seeing above are 3 squares or more and that is what confused me. Some of the chips in the sample quilt squares are much bigger than 4mm. I actually went to 5mm and that was easier for me.
Glad to know you are providing the patterns.
Phil
Merrill
9 posts in 837 days
#10 posted 821 days ago
Here is my first attempt at a pattern. Just squares inside squares.
MyChipCarving
#11 posted 821 days ago
That pattern will carve very nicely, Merrill!
Well done!
Merrill
9 posts in 837 days
#12 posted 820 days ago
I used Google Sketchup to do the drawing. Then once I get it like I want I export it to photo editing software to get the size i want. In this one I inscribed squares inside squares rotating 90 degrees each time. Then I erase what I don’t want. I worry that the triangles are too large for me to carve nicely.
MyChipCarving
#13 posted 820 days ago
If the triangles are too large, subdivide them to make them more manageable. If dividing them in half still leaves them too big, try dividing in thirds or fourths.
