Outfeed and assembly table with tool stations - small shop challenge #4: Outfeed table done
Blog entry by Mike_D_S posted 07-10-2016 03:05 PM 1429 reads 0 times favorited 7 comments Add to Favorites Watch
« Part 3: Outfeed table base framed up Part 4 of Outfeed and assembly table with tool stations - small shop challenge series no next part
I spent most of yesterday finishing up the outfeed table.
I started by making up a small alignment plate for the doghole drilling. The plate was basically two rows of dogholes in the spacing needed. I clamped the plate to the end of the top and drilled the first 8 holes. Then I slid the plate over one row and used some birch dowel through a couple of dogholes in the plate and the top to line up the second row to drill nd clamped the plate. Drill the next row, then repeat by indexing the new row of the last row drilled. They’re not perfectly straight, but close enough.
You’ll notice I left some space undrilled and this was two reasons. One, since this will be an outfeed table, I need to still route slots for the miter bar clearance for my sled, miter gauge, etc. Additionally, it’s likely I’ll get more sawdust from the saw in the area in line with and closer to the blade, so leaving more solid top should help with dust falling through the top. So I drilled one line of holes across the front and another line up the far side, but left most of that area solid.
After driling the dogholes, I used roundover bits to ease the corners (1/2”) and top edge (1/4”) and then with my small DW router and the plunge base I used a 1/8” roudover to ease the tops of all the dogholes. The top is still plenty stiff.
So here’s a shot of the top.
After finishing the top, I spent some time leveling the top of the base. For the base, I used 3” lag screws to tie the legs to the framing running left to right. For the cross members running front to back I used LV bed bolts. I backed off all the connectors just a bit and then leveled the frame top. After that was done, I installed the top to the frame using screws through upper frame parts.
After installing the top, I needed to level it up to the back of the saw with just a small 1/32 to 1/16” drop so nothing gets caught or lifted by the edge of the outfeed table coming off the saw. But before I did that, I spent some time checking and re-leveling the saw wings and router table extension. Once I was happy with the saw itself, I used my long level on the saw and raised the outfeed table to the correct height and alignment.
With the outfeed table basically done, I started working on the tool stations. I had already cut the parts when I was cutting the table parts, so I marked out all the hole locations and drilled them out on the drill press. The plan was to use a 3/8” bolt as the axles inside a piece of aluminium tube for the rotating piece and 3/8” threaded inserts in the other piece to receive the bolt. Both the outside ID of the AL tube and the threaded inserts was 1/2”, so I used a 1/2 forstner bit for all the holes. Then I rounded the end of the piece that rotates under the ply tool rest for clearance and assembled the tool stands.
Fitting the ends of the supports to make the tool stand tops level was a bit finicky and I had to take the support legs off several times to cut off more materials, but at the end they are good. For the lathe stand, I used metal latches into blocks to make sure the support legs couldn’t move. For the grinder stand, I just used notched lower legs.
So here are a couple of shots of the table with the stands up and the stands down and the tools stored. And then one more showing how I packed a bunch of stuff into the storage area. You notice I did make a mistake with the frame assembly and that the grinder station doesn’t fold down flush. It would have required fairly significant rework of the frame to fix, so I just left it for now. I have a couple of ideas about how to fit it, but I decided to just let it go for the time being to see if it really bothers me.
And one more of me using the table in anger for the first time.
-- No honey, that's not new, I've had that forever......
7 comments so far
View BurlyBob's profile
BurlyBob
6031 posts in 2503 days
#1 posted 07-10-2016 03:21 PM
Thanks Mike. There’s a lot of your table I think I’ll refer to when I build my own outfeed table. Like yours I want some storage underneath but I need to leave room for the sawdust hose.
View Dwain's profile
Dwain
584 posts in 4097 days
#2 posted 07-10-2016 03:28 PM
That’s a lot of dogholes! Do you have a vice installed? I like your shelves. Nice work.
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
View Mike_D_S's profile
Mike_D_S
557 posts in 2452 days
#3 posted 07-10-2016 07:42 PM
@BurlyBob,
If you are thinking about the table saw dust collection, between the table saw top extending over the back, the three or four inch gap between the TS and some space I left behind the tools under the shelf there is room for the dust port for the TS. You can see in this pic the hose coming off the back of the saw.
@Dwain,
I don’t plan on installing a vise. I have a Sjoberg smart vise that I have been using clamped to the router table. For the outfeed table, my plan is to use wonder pups and wonder dogs for clamping.
One of the specific things I wanted to have was a place to have a couple of right angle clamping squares for glueing up cabinet doors and screwing together pocket holed face frames. There are enough dogholes to get 3 right angle frames and be able to do a number of doors at the same time.
Mike
View htl's profile
htl
4321 posts in 1397 days
#4 posted 07-10-2016 09:06 PM
Nice setup!
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
View Notw's profile
Notw
678 posts in 1991 days
#5 posted 07-11-2016 03:48 PM
On your swing out tool rest do you have to lift the lathe off of the tool rest and put it below the bench or am I missing something?
Mike_D_S
#6 posted 07-11-2016 04:36 PM
Yes, I have to manually lift the lathe and grinder onto their work stations. I have a little latch that holds the grinder station up high so I can slide the lathe and grinder out from the side of the bench. They both need to be clamped down at the moment, but I will install threaded inserts and use locking knobs.
The height of the lathe station was specifically chosen as it puts the work at a very comfortable working height for me. This coincidentally puts the lathe center just high enough above the table that I can just set the lathe dust hood I’m putting together on the table top with a couple of small dowels to fit into a couple of the dogholes.
View Notw's profile
Notw
#7 posted 07-11-2016 08:00 PM
very cool, I would really like to be able to swing my grinder up like one of the appliance lifts people use in kitchens but the brackets for those are super expensive. Very nice job on this, i find you can never have too many flat surfaces
