DIY Table Saw Router Extension Wing #2: More views of the basic table
Blog entry by Mike_D_S posted 12-30-2015 06:06 PM 1752 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 1: Starting with a solid foundation Part 2 of DIY Table Saw Router Extension Wing series Part 3: Finally getting somewhere- lift installed »
While it’s only 12 inches wider than the stock wing I took off, it looks like a lot of extra table.
This morning in the cold hard light of day there were a few things I still needed to do. After sitting overnight mounted to the table saw, the phenolic top right at the joint to the saw had come up about 1mm on one side, I added an additional piece of ply to double up the skirt where it connects to the saw. I’m going to drive in a couple of pocket hole screws to make sure that joints stays nice and tight.
At a minimum it’s a nice piece of additional real estate on my saw.
And one more with my Jessem fence mounted. I typically work to the left side of my saw, so I should be able to leave my router fence on except for the widest cuts. With the fence approximately where I think the router will be, I’m only losing maybe 2 or 3 inches in cut width. Since I generally break down my ply on saw horses before cutting to final size, this isn’t a big deal for me and I mostly use my sled anyway.
-- No honey, that's not new, I've had that forever......
1 comment so far
View NormG's profile
NormG
6202 posts in 3059 days
#1 posted 01-01-2016 05:55 AM
Well done, looks great. I plan doing the same addition to my TS
-- Norman - I never never make a mistake, I just change the design.
