M & M Dispenser Friday
Blog entry by Mean_Dean posted 12-19-2015 12:06 AM 1406 reads 1 time favorited 7 comments Add to Favorites Watch
Ok, made some good progress today!
Found some screws the right size, and drilled the holes in the metal lid.
Next, put the stop screw into the box (neck), then routed the slot in the bottom of the slider, and fitted both to my satisfaction.
Then routed a cove detail on the edges of the top and bottom, using a 3/8” cove bit. I’d rather have used an Ogee bit, but don’t have one!
I sanded the top and bottom to 220, including the coves, the endgrain to 400. I forgot to sand the slider, so will do that tomorrow. When that’s done, all parts will be finished sanded!
Lastly, sprayed 2 coats (so far) of sanding sealer on the knob, sanding between coats. I’ll probably go another coat after sanding, and then the knob will be ready for paint.
That’s all for today!
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
7 comments so far
View Don Broussard's profile
Don Broussard
3704 posts in 2492 days
#1 posted 12-19-2015 12:58 AM
Looking good there, Dean! I can see it now filled with peanut M&Ms (but I’m guessing it’s made for the regular M&Ms).
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
View Mean_Dean's profile
Mean_Dean
6916 posts in 3387 days
#2 posted 12-19-2015 01:19 AM
Thanks, Don!
It will also work with peanut M & M’s.
View  woodshaver Tony C   's profile
woodshaver Tony C
6278 posts in 3593 days
#3 posted 12-19-2015 03:03 AM
I’m liking it Dean! It’s shaping up really nice!
I forgot to tell you that I put these little anti-skid pads on the bottom. I just cut one in quarters and stick them on. This helps keep the dispenser from sliding around. I got them at Home Depot.
Sorry to hear your email is not working still. Bummer!
-- St Augustine FL, Experience is the sum of our mistakes!
View BusterB's profile
BusterB
1970 posts in 2248 days
#4 posted 12-19-2015 09:12 AM
Wow….much nicer than mine…by a long shot. Is that lacewood? Great job so far Dean
-- Buster, Ocoee TN (Critics are men who watch a battle from a high place then come down and shoot the survivors - Hemingway)
Mean_Dean
#5 posted 12-19-2015 04:13 PM
Thanks for the comment, Buster! The wood is actually Leopardwood.
View ClydeWoodArt's profile
ClydeWoodArt
7 posts in 465 days
#6 posted 04-06-2018 03:03 AM
A very cool project! I made 3 similar ones for my Grandchildren’s Christmas 2017. They work wit h M&Ms, Jelly Belly, and peanuts.
Your project is very cool and clever. I like the details you put on.
A suggestion regarding an Ogee bit: While I was saving up for buying one, I made ogee edges by making two passes, one with a cove bit and another with a beading bit. You need a router table with fence because you take the ball bearing off the beading bit to create the fillip curve on the piece.
-- B. Clyde Beck
Mean_Dean
#7 posted 04-06-2018 05:19 PM
Clyde, thanks for the comment!
I have a router table, and will take your advice on those two router bits.
