What To Do With This Board? #14: Finished!
Blog entry by Mean_Dean posted 05-27-2015 02:54 AM 1366 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 13: Stained Part 14 of What To Do With This Board? series no next part
Hey Guys!
Well, she’s all done!
But first things first…...
As we discussed in the last installment, I decided to use clear shellac, as opposed to amber shellac, since I couldn’t see any difference in the two shades on the test board I made up earlier. I chose to finish the box with shellac as it has no odor to it once it’s cured, unlike oil-based finishes like polyurethane.
I applied the first coat, and let it dry for 2 hours.
The box surface after the first coat was pretty rough, so I sanded it smooth with 320 grit.
I’ve learned that any finish will raise the grain, some more than others, even oil-based. Shellac is thinned with denatured alcohol, and does raise the grain. Less than water-based, but more than oil-based.
After sanding the first coat smooth, I applied two more coats, at 2-hour intervals, sanding between coats. Shellac dries at gloss sheen (I’ve never seen any other sheen in the can other than gloss.) On previous projects, I’ve knocked back the sheen with 0000 steel wool, but on this box, I kinda like the gloss!
So, here she is, in all her glossy glory!
I enjoyed this blog, (my first one ever!), and I hope you did, too!
Thanks to everyone who followed along, and commented—I really appreciate it!
Until next time,
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
3 comments so far
View CFrye's profile
CFrye
10038 posts in 1744 days
#1 posted 05-27-2015 11:34 AM
Nicely done, both the blog and the box, Dean. Thanks for taking the time and sharing. Spline jig is on the To Do List.
-- God bless, Candy
View Mean_Dean's profile (online now)
Mean_Dean
6115 posts in 3051 days
#2 posted 05-27-2015 11:36 PM
Thanks, Candy!
When you build your spine jig, I highly recommend putting an aluminum runner on the bottom of the “fence.” If you try to use the tablesaw’s fence, you’ll never quite get the jig’s kerf in the exact same spot every time. The runner assures that the kerf will never move, so that you can align your story stick precisely.
Some lessons I’ve just had to learn the hard way….......!
CFrye
#3 posted 05-28-2015 12:50 PM
Thanks for the insight, Dean. The plans I have are for a box making sled-jig-thing from The Ultimate Table Saw Book (or something to that effect). I already have the cross cut sled part finished, just have to add the bells and whistles.
-- God bless, Candy
