The Craftsman's Path #58: Sculpted Rocking Chair - Laminating the Rockers and Back Braces
Blog entry by Mark Mazzo posted 264 days ago 289 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 57: Sculpted Rocking Chair - Coopered Headrest and Ripping Thin Rocker Strips Part 58 of The Craftsman's Path series Part 59: Sculpted Rocking Chair - Seat Joinery »
Moving on from the work of roughing out components, it was time for some laminations. After making the forms I went to work with lots of thin strips in hand to create the rockers and back braces for the chair. The glue-filled process is covered in the latest post on my blog. Thanks for reading!
Laminating the rockers
3 comments so far
View David's profile
David
1982 posts in 1032 days
posted 264 days ago
Mark -
This is a fun and inspiring blog to follow. I like the idea of adding the aluminum alignment stops. I will bet those were very helpful aligning strips slippery with glue. The rockers look awesome!
David
View Mark Mazzo's profile
Mark Mazzo
343 posts in 805 days
posted 263 days ago
Thanks, David.
The alignment stops were definitely helpful. WIth that many lamination strips and that much glue, these things tend to move around when you are clamping them to a curved surface! The alignment also assures that there will be enough material after cleanup to reach the finished width.
The rockers are not yet complete. I still have to glue up stacks for under each of the legs and then there is the shaping…the last of the back braces are in the form as we speak!
—Mark
View Betsy's profile
Betsy
2386 posts in 789 days
posted 260 days ago
Somehow, I managed to drop this from my watchlist! I learn something new every time I see your posts. I appreciate the time it takes to be so detailed in your descriptions. Looking forward to the next installment!
