The Craftsman's Path #54: Modern Shaker Table - String Inlay and Glue Up
Blog entry by Mark Mazzo posted 310 days ago 560 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 53: Exposing the Jointer... Part 54 of The Craftsman's Path series Part 55: Modern Shaker Table - Completion »
I moved on to milling and installing the string inlay on the table before gluing it up and readying it for finish. Take a look at the latest post on my blog for the details. Thanks for reading!
Gluing the stringing
5 comments so far
View Betsy's profile
Betsy
2386 posts in 790 days
posted 309 days ago
Mark – your posts are always informative. I learn something almost every time!
What type of glue do you use for your inlays? I ask as I wonder about the swelling of the string as you apply it—wondering if hide glue is what would be used.
Also – with such small stinging – do you apply the glue to the string or into the inset? Either way—- what do you use to apply it?
One more—- how proud of the top is the stringing?
Thanks in advance—looking forward to the next post.
View motthunter's profile
motthunter
2079 posts in 693 days
posted 309 days ago
good progress…please keep us posted
-- making sawdust....
View Mark Mazzo's profile
Mark Mazzo
343 posts in 807 days
posted 309 days ago
Betsy,
I just used yellow wood glue for the stringing. I put a small amount of glue directly into the channels and then spread it a bit with a brush. I was as careful as possible, but it was definitely not a neat operation ;-) However, I knew that the stringing would be scraped/planed down to the surface so, that would take care of any squeeze-out. FYI – the stringing was about 1/16” of an inch proud of the surface before I scraped/planed it down even.
If you work quickly you can keep ahead of any swelling. Though, because of the tightness of the fit there is a bit of hydraulic pressure to deal with from the glue.
This stringing was 3/16” of an inch wide, so it was not as delicate as some. I would think that the more delicate the stringing the bigger the issue with potential swelling. Hide glue might be a good choice – though the open time for hot hide glue is not too long.
Mark Mazzo
posted 309 days ago
Motthunter,
Keep a lookout for the final post of the finished product soon!
Betsy
posted 308 days ago
Thanks for the answers Mark. I’m looking forward to the next entry.
