Upgrading Sawstop Motor
Blog entry by Manitario posted 03-09-2014 07:13 PM 10261 reads 2 times favorited 14 comments Add to Favorites Watch
I have a 1.75hp PCS Sawstop. I considered the 3hp version initially, but then balked at the extra cost and reasoned that 1.75hp would be more than enough. Fast forward two years and most of my woodworking involves thick 2” slabs…even with a sharp, thin kerf blade the motor really struggles. So, I called Sawstop to see if it was possible to upgrade the motor rather than have to buy a whole new saw. They were very helpful and explained that the 1.75 and 3hp PCS saws are the same, just with different motors and switch boxes. So yes, for $550 I could buy the motor and switch assembly and upgrade (which is basically the price difference between the two saws). I’d looked on the web to see if someone else had done the switch, but couldn’t find anything. Swapping motors was easy and took just over an hour; I documented the process in case anyone else does it.
Remove gas shock (top and bottom bolt):
Remove motor by removing mount bolts (19mm socket) and lift free from drive belt
Install new gas shock (easier to do with motor out)
Remove switch assembly and control box:
control box bolts:
Open switch assembly by removing seven screws
Then unclip white plug from old 120V control box and clip in plug from new control box. Reassemble and reinstall switch and control box onto saw
Reinstall new motor (may need someone to help hold the motor while you tighten the bolts, it’s heavy!) Make sure motor pulley lines up on drive belt. Drive belt tension: it should deflect less than 1/4” with finger pressure.
Feed motor power wire through opening in saw. Wire motor.
You’re now done, enjoy 3hp!
14 comments so far
View Mean_Dean's profile
Mean_Dean
6554 posts in 3170 days
#1 posted 03-10-2014 12:54 AM
All-in-all, looks like it went pretty easily! Gotta love it when that happens!
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
View Rob's profile
Rob
704 posts in 3094 days
#2 posted 05-21-2014 08:50 PM
Not bad! In the end you do end up paying a little extra ($120) but you end up with a spare 1.75hp motor. This is a great option for anyone who isn’t sure if they need the extra horsepower up front.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View Manitario's profile
Manitario
2630 posts in 2906 days
#3 posted 05-22-2014 10:38 AM
Thanks Rob; I wasn’t sure I needed 3hp when I bought the saw, but it was nice to be able to do such a simple upgrade when I needed it.
117115 posts in 3600 days
#4 posted 05-22-2014 03:06 PM
Good thinking,well done.
View RustyHacksaw's profile
RustyHacksaw
142 posts in 1287 days
#5 posted 04-21-2015 04:23 PM
Did you find a use for, or did you find a way to recoup some of the cost by selling your old motor? Would there be a market for it?
Manitario
#6 posted 04-23-2015 06:08 AM
I kept the motor, I’m sure that someday I’ll find a use for it, I’‘m not sure there’s a big market for a used 1.75 hp Sawstop motor.
View Alan72's profile
Alan72
211 posts in 2056 days
#7 posted 07-18-2015 03:23 AM
Are you glad that you changed over to the 3hp motor? I have the same saw and was toying around with the same idea.
Manitario
#8 posted 07-18-2015 03:52 PM
Alan; yes after a year of use, I’m glad that I’ve upgraded. The saw used to regularly have trouble with 8/4 stock, now I can cut pretty much any thickness of wood with ease.
View MikeNelson's profile
MikeNelson
3 posts in 927 days
#9 posted 12-05-2015 02:03 AM
I am making this same switch, in case anyone is interested in purchasing a 1.75 HP motor and 110 v wiring.
View Hewy's profile
Hewy
27 posts in 2710 days
#10 posted 12-06-2015 01:12 AM
I have the 1.75 HP motor which I run on 110V volts. I have found that that the saw runs the best if
you run a dedicated #12 wire, 20 amp circuit directly to the saw. When I first hooked up my saw I
plugged it into an existing 20 amp wall plug, but this circuit had other things also connect such as lights
and a radio, which lowers the available amps to the saw motor. After I made this change I cut 8/4 red oak with a full kerf 40 tooth Forrest blade with no trouble. The other thing to consider is changing the motor and switch to run the saw on 220 volts . I know this is a option from Saw Stop. The saw still has the same 1.75 HP but uses less amps.
Hewy
MikeNelson
3 posts in 927 days
#11 posted 12-22-2015 05:00 PM
I have made the conversion and I agree with Manitario, I did experience a bit of bog down in the past, but not now! Also, it was pretty straight forward, a small thing, when you order parts, the pulley comes installed on the motor, so no need to order a pulley, set screw or key.
View KZrusterations's profile
KZrusterations
1 post in 334 days
#12 posted 07-20-2017 10:35 AM
I know this is a pretty old blog but I’m hoping the man who wrote this blog sees this! Hello my name is kevin and I recently purchased a pcs sawstop on an auction and it didn’t come with a motor. Seeing that you have a extra one would you be interested in parting with it?? It would be a great help to me. Thank you
MikeNelson
3 posts in 927 days
#13 posted 07-20-2017 11:11 AM
I know this is a pretty old blog but I m hoping the man who wrote this blog sees this! Hello my name is kevin and I recently purchased a pcs sawstop on an auction and it didn t come with a motor. Seeing that you have a extra one would you be interested in parting with it?? It would be a great help to me. Thank you
Yes I am, I’m in central Illinois. Near Champaign IL, is it possible to pick it up? Shipping might be prohibitive
Manitario
#14 posted 07-20-2017 03:50 PM
Hi, yes I have the motor still and I think that I kept the strut and the switch too. I’m up in Canada and the motor weighs a good 20-30lbs so it might not be worth it for you for me to ship it. I’d talk with Sawstop and get a price on one of their motors; when I upgraded the 3hp motor they sold me was pretty reasonable.
Let me know, happy to ship it to you if you want it.
