An ongoing project for me has been to rehab one of my grandfather’s planes that he passed down to me. The plane is about the size of a #4 Stanley, and is of the “Tecomaster” brand, which I understand was produced for the Eaton’s line of department stores. With the little bit of knowledge I have of planes, I didn’t expect much from it, any more than I would a “Walmart” brand plane, however, the fact that it had been my grandfather’s inspired me to at least get it into working condition. That, and it happens to be the first bench plane that I’ve owned. I have a #4 Stanley and a Miller Falls series 90 on their way, courtesy of Ebay; upon their arrival all my motivation to work on the mighty Tecomaster will fade…
Flattening the sole was a beast…many, many sheets of 60 grit sandpaper gave their lives to the cause…
Frog is in good shape, I didn’t bother doing much more than making sure the iron seated firmly against it.
Sharpened the iron to a 25o bevel…Cap iron fit closely to the plane iron
Success!! (worked well for pine, although you could plane pine with a screwdriver…stepped up to fir…still curly smooth shavings…stepped up to walnut…had to close the mouth down to a sliver, but still got some nice shavings off)
I’ll have to wait for my other planes to arrive and compare…
Thanks for reading!
-- Rob, Sault Ste. Marie, Ontario
7 comments so far
David Grimes
home | projects | blog
2114 posts in 806 days
#1 posted 690 days ago
Looks like a righteous plane to me. I hear those red frogs are poisonous, though. ;=)
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
Smitty_Cabinetshop
6374 posts in 784 days
#2 posted 690 days ago
Rob- Always cool to see way-off-brand tools go to good use. Can’t tell – are the knob and tote plastic or painted wood? And you may want to read up on sandind the face of the frog, the part that faces the iron. Good contact there improves the stability of the tool in tougher woods… Nice work!
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
ratchet
1189 posts in 1953 days
#3 posted 689 days ago
Wow excellent save and good refurb! What a nice user now.
Bertha
13111 posts in 859 days
#4 posted 689 days ago
With shavings like that, there’s not much to argue about:) Looking at the plane, my first thought would be that the lateral adjuster might not work as well as desired. Am I right? I think lateral adjusters are over-rated to begin with (I also like to break them, which supports my position;).
Smitty_Cabinetshop
#5 posted 689 days ago
My dad’s maroon-colored #4 Stanley smoother has that same bent metal lateral. I don’t use it often, but it’s one of those set it and forget it things that don’t seem to aggravate much if at all… Wonder if Stanley made this one, too, in the 60s?
Don W
9933 posts in 733 days
#6 posted 689 days ago
shaving show it work. Nice restore.
WayneC
9596 posts in 2263 days
#7 posted 689 days ago
Well done.
