New Mobile Work Station #3: Dog Holes and Clamp slots
Blog entry by MT_Stringer posted 11-23-2013 11:50 PM 3417 reads 3 times favorited 6 comments Add to Favorites Watch
« Part 2: Frame Assembly Part 3 of New Mobile Work Station series Part 4: Project Complete »
With the weather krummy, I stayed indoors and worked on the table top. I laid out the dog holes and clamp slots. Then I drilled the holes with a 7/8 inch Forstner bit. For the clamping slots, I drilled each end with a 1 1/4 inch Forstner bit. Next I drew the lines in between the holes and cut out the slots with a jig saw leaving a little waste inside the line. All that is left is to set up my router with a straight edge and trim the slots to final size with a flush trim bit.
Here are a few pics of the work done today and some test fitting of my jigs. As you can see, the holes and slots allow for a variety of clamping options.
After I get the Formica laminated on the top, I will trim all holes and slots and bevel the edges slightly. The final result should look like my drill press table.
6 comments so far
View David Dean's profile
David Dean
608 posts in 2926 days
#1 posted 11-24-2013 12:12 AM
sweet.
View socrbent's profile
socrbent
613 posts in 2296 days
#2 posted 11-24-2013 03:57 AM
Thanks for sharing this blog. I can see lots of uses for this type of small movable table with solid construction. You have given me lots off things to think about as I design and create a similar table that will also serve as an outfeed table when needed.
-- socrbent Ohio
View MT_Stringer's profile
MT_Stringer
3172 posts in 3258 days
#3 posted 11-24-2013 04:51 AM
Thank you. I have been inspired by others that have shared their projects so I am paying it forward.
View Roger's profile
Roger
20929 posts in 2831 days
#4 posted 11-25-2013 12:54 PM
Makes for a nice universal top
View Tugboater78's profile
Tugboater78
2746 posts in 2219 days
#5 posted 11-27-2013 02:35 AM
nice table, great idea, need something to hold my kreg jig and my miter box.
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
MT_Stringer
#6 posted 11-27-2013 03:43 AM
Thanks. The weather has been to bad too laminate the top. I have do it outside because there is a natural gas fired water heater about 15 feet from the table. So, I will have to wait a day or three.
I made a holder for the extension cord.
And cleaned up the clamp slots with the router and a flush trim bit.
A friend donated a piece of Formica so I wouldn’t have to buy a full sheet.
