New Mobile Work Station #1: First Things First - The Plan
Blog entry by MT_Stringer posted 11-19-2013 08:00 PM 6147 reads 12 times favorited 4 comments Add to Favorites Watch
no previous part Part 1 of New Mobile Work Station series Part 2: Frame Assembly »
Today I am going to start building a mobile workstation/cart or whatever you want to call it. No doubt mine will be similar to carts others have built, but customized to fit my needs. So, here are my ideas.
The Plan
Table use:
I plan to use the table for things like:
  • a sanding area
  • surface for mounting the PC dovetail jig
  • mount for the pocket hole jig
  • area for clamping glue ups.
  • other uses where work piece needs to be held in position via clamps.
Construction Details:
  • Table top should be 20×36 or thereabouts. The narrow width will make it easy to move around my small work area.
  • Top to be constructed of plywood. I still need to check out what materials I have on hand. The top may be constructed of 1/2 inch Baltic birch laminated to make it 1 inch thick. Or just 3/4 inch plywood. Regardless, the surface will be covered with Formica to protect the surface from glue spills and drips.
  • Top will be constructed with 7/8 inch dog holes and slots for F style clamps. My dogs are 7/8 inch and the opening is perfect to insert 1/2 inch pipe for mounting pipe clamps from below.
  • Frame construction to be 2×4 stud material and other material on hand.
  • Add storage where available and a drawer or two.
  • Mount an electrical outlet strip for handy access.
  • Create area for small item storage.
  • Jig storage for:
    1. Porter Cable Dovetail Jig
    2. Kreg Pocket hole jig
    3. Table saw tenon jig
Some fellow LJ’s have given me inspiration for this cart including:
vrice
http://lumberjocks.com/projects/92047
sawdustmaster
http://lumberjocks.com/projects/47335
markgipson
http://lumberjocks.com/projects/80274
toddbeauliew
http://lumberjocks.com/projects/79211
stumpynubs thread “Ultimate Shop Cart”
http://lumberjocks.com/topics/52506
And of course, ShopNotes Magazine Vol 21 Issue 124
So, with that said, I am off to buy a couple of 2×4’s to go with what I already have.
Pics to follow.
4 comments so far
View Handtooler's profile
Handtooler
1603 posts in 2188 days
#1 posted 11-19-2013 11:33 PM
Question! Might this bench, if the proper hight, be positioned as a tablesaw outfeed table as well? I really like the dog holes and slots that could be used to pass clamps through. The several others that you’ve included surely picqued my fancy Thanks for the many ideas for this novice.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View MT_Stringer's profile
MT_Stringer
3172 posts in 3287 days
#2 posted 11-20-2013 02:00 AM
Russell, it’s main purpose is to add a little extra work area that can be moved around as I reposition my tools. It will house my bigger jigs that don’t have a home (no wall space left). I have my one and only table that is about 30×40 inches that serves as out feed table/assembly table and work table.
I am in a one car garage so space is tight. Thanks for asking. Hope you find some inspiration for your project.
MT_Stringer
#3 posted 11-20-2013 03:12 AM
Here’s my plan. Not the greatest amount of detail, but something I can work with. I have the basic pieces cut and started the dadoes, then I got tired and quit for the day. :-)
You will have to use your imagination. I still have to work out the jig storage and drawer placement.
Top view
Side view.
MT_Stringer
#4 posted 11-21-2013 02:37 AM
Got some work done today. The frame pieces have been cut and milled to final size.
End pieces
Legs and sides
Dry fit
