Modifying the Kreg Pocket Hole Jig #3: Final Assembly
Blog entry by MT_Stringer posted 11-14-2013 05:52 AM 14197 reads 1 time favorited 9 comments Add to Favorites Watch
« Part 2: Designing the new jig Part 3 of Modifying the Kreg Pocket Hole Jig series no next part
Time to get this project wrapped up.
I covered the plywood deck with white Formica as well as the material supports and the rear support for the cylinder. After trimming the laminate flush with the plywood, I used a chamfer bit to bevel the edges slightly.
Now for the nitty gritty.
Here is a close up of the cylinder mounted on the jig. The original four 10-24×1 inch machine screws secure the front of the plate. Two 1/4 -20×1 inch round knobs attach the rear of the plate to the sled. If necessary, I can remove the cylinder as a unit.
IT’S ALIVE!!!
Piston retracted.
Piston extended.
Foot operated switch with muffler.
Overview
I have my parts box fastened to the sled near the edge so I can loosen the latches. They secure the lid really well.
The black piece is the Kreg Micro jig.
And now for the good part. If something breaks, I can simply remove the four screws and the two 1/4 inch round knobs, remove the air cylinder unit and replace it with the original clamp!!! :-) A special thank you goes out to Crank49 for making that suggestion.
But wait, there is more!
If I need to drill pocket holes in 2x lumber, I will have to reposition the air cylinder. To do that, I simply remove the four 10-24 machine screws which will free up the sled. Then I will need to remove the four wood screws on the bottom side of the sled which keep the rear cylinder support in place. After determining the position for the cylinder, put the screws back in the aluminum plate, and drill new screw holes on the underside of the sled so the rear support will stay put. No need to remove the two 1/4 – 20 round knobs.
I drilled a few holes and the jig is working great. I had the air compressor set at 80 psi. I think I can easily reduce it to 60 psi.
The only thing left is to get a filter for the air line. The specs call for a 40 micron filter. HF has one that should work just fine.
I hope you enjoyed reading about this build as much as I did building it. My cabinet making should go a lot smoother next go round.
Mike
9 comments so far
View darthford's profile
darthford
574 posts in 1889 days
#1 posted 11-14-2013 06:34 AM
Oh man metal working and shiny cylinders and foot switches, very nice! On a larger scale I’d like to build an air clamp jig for gluing up dovetail tube amp head cabinets.
View Handtooler's profile
Handtooler
1542 posts in 2097 days
#2 posted 11-14-2013 11:35 AM
MT, Ya gotta patent those ideas and fabrication soon or Kreg will certainly steal them and market the Kit for several hundred dollars. Very nicely constructed!
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View sras's profile
sras
4790 posts in 3094 days
#3 posted 11-14-2013 03:28 PM
Nice project! Looks like you are set up for mass production.
View MT_Stringer's profile
MT_Stringer
3160 posts in 3196 days
#4 posted 11-22-2013 03:48 AM
And now for an update. I finally got a chance to drill some pocket holes in both 3/4 inch material and 1 1/2 inch 2×4 material. What I learned is that I can simply screw the rubber foot into the coupling about 1/2 inch and then lock it down. The piston will extend as far as it can and then stop and hold pressure against the 2x work piece without damaging it. That made the work go smoothly and quick. I am loving the foot switch.
I routed the air line through a 40 micron filter, which I have mounted to one leg of my work bench.
MT_Stringer
#5 posted 12-12-2013 05:59 PM
And…it can also be used as a pean cracker! :-)
Here is a short video demonstrating the pecan cracker in action.
View ,'s profile
2387 posts in 3512 days
#6 posted 03-24-2015 02:14 AM
Wow that is really cool. Never seen that sort of set up.
View eringuet's profile
eringuet
12 posts in 2517 days
#7 posted 01-08-2016 04:35 PM
Hi Mike,
Do you have the specs of this pneumatic cylinder?
I’m thinking of building a hinge boring jig to setup permanently on a benchtop drill press and I think your cylinder would work great for this application.
Nice work on the jig. Sorry for reviving this old post.
MT_Stringer
#8 posted 01-08-2016 05:15 PM
Hi Mike,
I m thinking of building a hinge boring jig to setup permanently on a benchtop drill press and I think your cylinder would work great for this application.
- eringuet
I got the air cylinder from Ebay – lots of choices. Search for Bimba air cylinder.
Since I didn’t know any better, I bought a 2 inch bore 1” stroke. If I had to do it over again, I might get either a 1 1/2 inch stroke or maybe a 2 incher. Actually, it doesn’t matter, but would allow you to use thicker stock. When the air cylinder extends, it goes as far as it can then stops. It will hold the pressure against your stock until you release it.
Note: Freight Props.com probably has everything you would need to get set up.
Hope this helps.
Mike
eringuet
#9 posted 01-08-2016 06:15 PM
I found that you can get these fairly cheap from Aliexpress.
I assume you use a 5-way foot valve with this? Double-action correct?
Thanks for answering.
