homemade 12" jointer #3: Running for the first time! And with some pics!
Blog entry by Cole Tallerman posted 09-25-2012 03:19 AM 11046 reads 3 times favorited 8 comments Add to Favorites Watch
« Part 2: Sides done, cutter head mounted, and motor mounted. (only sketchup, pics next weekend, sorry!) Part 3 of homemade 12" jointer series no next part
You may have seen my last posts with the sketchups. i got the sides cut, the parallelogram mechanism working, and the motor mounted. i had to use a different mounting system then in the plans because the belt i got was way to long. i ended up mounting the motor to the underside so i also had to have a different tensioning system which actually worked out quite well. I have no patience so i needed to see the thing run! it ran way smoother then i ever thought it would with almost no overall vibration For some reason (i think because i used a polyurethane belt) im getting almost no belt vibration.
The jointer running! (as you can see there is almost no vibration in the belt)
Bearing mounts:
Parallelogram:
Motor mount: (not so clear) the motor is mounted on a pivoting metal shaft that came in the planer. I banged a nut into the wood and threaded a bolt through that pushes against the motor. i need to make a hand wheel.
8 comments so far
View markswoodcraft's profile
markswoodcraft
175 posts in 2145 days
#1 posted 09-25-2012 03:45 AM
cant wait to see the table and fence on it!
117115 posts in 3601 days
#2 posted 09-25-2012 03:47 AM
Wow what an ambitious project ,very cool
View dub560's profile
dub560
615 posts in 2937 days
#3 posted 09-25-2012 09:33 AM
Incredible amount of work you’ve done so far
-- Life is enjoyable especially when you borrow from people
View Cole Tallerman's profile
Cole Tallerman
392 posts in 2209 days
#4 posted 09-26-2012 02:37 PM
Thanks guys! The next step is to get the bottom and ends installed and then i will get to the tables
View wunderaa's profile
wunderaa
248 posts in 2227 days
#5 posted 12-10-2012 03:44 PM
Any new progress??
View Woodknack's profile
Woodknack
11775 posts in 2404 days
#6 posted 01-27-2013 12:08 AM
I see the finished jointer in your shop pics, how’s it working? I also see you didn’t go with solid maple.
View TheOtherMrRogers's profile
TheOtherMrRogers
42 posts in 2206 days
#7 posted 08-15-2014 12:56 PM
Great work. I’ve been thinking about this project for a while. Where did you get your belt?
-- For what does it profit a man to gain the whole world and forfeit his soul?
Cole Tallerman
#8 posted 08-16-2014 04:13 AM
Great work. I ve been thinking about this project for a while. Where did you get your belt?
- TheOtherMrRogers
I noticed that my Sawstop contractor saw had the exact belt that I needed. I called up sawstop, And the guy was so interested in the jointer that he traded me a free belt for some pictures!
