New Crib #6.....Finally Got 'er Whipped
Blog entry by MOJOE posted 11-28-2009 09:46 PM 1148 reads 0 times favorited 3 comments Add to Favorites Watch
Well, I finally finished up my son’s crib….well ahead of my Feb. deadline I might add. Once everything was mocked up and fit nicely, I took the headboard portion off and sprayed the finish on in 2 sections. I used Bullseye Sealcoat tinted with 40 drips of Transtint Medium Brown (40 drips cause I didn’t have a measuring device). Anyway, sprayed on 6 coats with 320 sanding between each. The final coat was buffed with 0000 steel wool. I am pretty happy with how it turned out…..especially since I didn’t follow any pattern. I also had my first experience with a spray applied finish. Worked well, I picked up a Critter spray gun, and though my compressor is a bit small, it worked fine. There are a few photos below…...next up…..matching dresser!
As always, all critiques are welcome,
joe
-- Measuring twice and cutting once only works if you read the tape correctly!
3 comments so far
View grizzman's profile
grizzman
7836 posts in 3273 days
#1 posted 11-28-2009 11:25 PM
very nice crib…you did a great job…the finish sounds like its smooth…dont want that boy gettin any splinters….thanks for shareing…
-- GRIZZMAN ...[''''']
View lumberdog's profile
lumberdog
245 posts in 3237 days
#2 posted 11-28-2009 11:50 PM
That is a great looking crib, i like the clean cut lines and it looks real safe.
-- Lumberdog.. Morley, Michigan
View janice's profile
janice
1116 posts in 3395 days
#3 posted 11-29-2009 10:02 PM
Very nice looking crib!
-- Janice
