Miter Saw Station #3: Counter Tops
Blog entry by Lenny posted 03-04-2014 01:58 PM 4487 reads 3 times favorited 11 comments Add to Favorites Watch
« Part 2: The Shelf Part 3 of Miter Saw Station series Part 4: The Fence System »
As noted in my previous post, the counter tops consist of a layer of MDF topped off with phenolic plywood. T-track runs the length of the countertop and is the means by which the fence system will be held in place. I purchased Woodpecker’s DP (dual purpose) track. The underside has a single centered t-slot that accepts ¼ inch hex bolts. Rather than rout the channel for the t-track, I cut the phenolic ply to fit around the track. Since the track is only ½ inch thick, you have to add a spacer to bring it to counter top level. Here’s a photo to show what I have described (minus the spacer).
With the saw sitting on the installed shelf in the approximate location it will sit, I placed a straight edge against the saw’s fence and extended it over the counter top and made a mark. That is exactly where the front edge of the track must fall. I continued taking precise measurements and then cut the rear pieces of phenolic ply to size. I attached these pieces to the MDF using hot melt glue to hold them in place so I could turn them over and nail them from below. Next, I glued and nailed the spacer for under the t-track alongside the rear phenolic ply. At this stage I placed the unit on top of the cabinet exactly where it would sit and drilled holes precisely where the ¼-20 hex bolts would go. I drilled through the spacer, the MDF and the cabinet tops. I placed bolts in the t-track, slid the t-track in place and assured a snug fit. Now I measured for the front pieces of phenolic ply, cut those and glued and nailed them just as I did the rear pieces. All that was left was to wrap the unit in solid maple and polyurethane the maple.
Next up: The fence system. Hint: Kreg does more than pocket hole jigs.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
11 comments so far
View Roger's profile
Roger
20898 posts in 2678 days
#1 posted 03-04-2014 02:02 PM
Very snazzy miter station Lenny
View grizzman's profile
grizzman
7836 posts in 3177 days
#2 posted 03-04-2014 02:32 PM
now just wait here lenny…this is going to be some sort of new generation saw system, im running a simple star fleet command here and your going for light speed….lol…enjoy it, nothing like using a good tool with good accessories…
-- GRIZZMAN ...[''''']
View goggy's profile
goggy
73 posts in 3290 days
#3 posted 03-04-2014 03:54 PM
You’ll like the phenolic ply. I have it on my router table.
View Lenny's profile
Lenny
1583 posts in 3401 days
#4 posted 03-04-2014 05:25 PM
Thanks guys. goggy, I’ve used the product once before on an auxiliary fence for my table saw. It’s wonderful stuff…slick and durable.
View aussiedave's profile
aussiedave
3114 posts in 1698 days
#5 posted 03-04-2014 10:24 PM
Very nice counter tops and Mitre saw work station, your doing an excellent job. Sure wish I could get phenolic ply here. I have enquired at all the hardware and wood suppliers and they look at me like I have two heads. Any wya that saw station is a great addition to the workshop. Thanks for posting.
-- Dave.......If at first you don’t succeed redefine success....
Lenny
#6 posted 03-04-2014 11:31 PM
Thanks Dave.
View NormG's profile
NormG
5889 posts in 2878 days
#7 posted 03-04-2014 11:36 PM
Great table top
-- Norman - I never never make a mistake, I just change the design.
View blackcherry's profile
blackcherry
3336 posts in 3697 days
#8 posted 03-05-2014 01:03 AM
Could service as a pub as well ha ha, looking sharp!
Lenny
#9 posted 03-05-2014 02:51 AM
Thanks, Norman. Wilson, that’s a clever and devious idea!
View Napaman's profile
Napaman
5526 posts in 3951 days
#10 posted 03-31-2014 01:55 PM
smooooooooth….
-- Matt--Proud LJ since 2007
Lenny
#11 posted 03-31-2014 03:07 PM
Thanks for the comments Matt.
