Proper Router Station #3
Blog entry by Lenny posted 03-08-2011 03:43 AM 5870 reads 4 times favorited 21 comments Add to Favorites Watch
Well it has taken me over a month to complete the drawers and doors for this router station cabinet but they are finished. I wanted to make this a series but had some problems doing so when I made my first post on this project. If interested, you can find the prior posts amongst my blogs. To summarize, I am making a router station cabinet for my Incra LS Positioner, Porter-Cable 7518 router and Pinnacle v2 router lift, all of which sit on a Woodpecker offset router table. I am fashioning the project after one made by Blake but making personal modifications as I go along.
I decided to make the drawers from Baltic birch with solid maple fronts. The fronts are 7/8” thick, the sides and back are ½” and the drawer bottoms are ¼”. I had every intention of using dovetail joints where the sides meet the front but ran into difficulties which I attribute to my router. I have a Leigh jig and I ran test cuts in pine and they came out fine. When I installed the first drawer front (maple) in the jig, I found that the router was not holding/locking the depth of cut. Anyway, I shifted gears and opted to make locking rabbet joints at the front. The back sits in a dado cut into the sides and the bottom floats in a groove in the front and side pieces.
Here is a photo of the drawer pieces laid out followed by one of the assembled drawer:
When I conceptualized these drawers I decided I wanted to use some purpleheart and yellowheart as accent wood. I came up with a horizontal stripe design. I cut ¼”x 1/4” strips of the two woods (slightly oversized depth-wise), glued them up to form a ¾” strip, dadoed out a ¾” wide by ¼” deep dado and inlaid the strip into the drawfront. Here are a couple of shots of the work while in process:
The drawers are overlay drawers so a 3/8” rabbet is cut all around the inside edges and then I did a ¼” roundover on the front edges. I used a block plane and cabinet scraper to bring the stripe flush with the maple. I had the best luck I ever had with my card scraper. One of the photos shows the wonderful, thin curls I was getting as I pushed the scraper through the stock.
The most enjoyable part of this project to date was the epiphany I had one day about making my own drawer pulls. I got the idea to fashion the pulls into the names of my family! I have a wife and two daughters so I did their names and mine. I made the pulls from purpleheart. I drew our names freehand on paper in bubble-letter fashion, making them about 7/8” tall. I glued the names onto strips of purpleheart using adhesive spray. Then I broke out the scroll saw and went to work laboriously following the lines. I chose spots to keep solid so as to maintain enough stock to have a functional pull. I went back and used a Dremel tool to carve out the spots I didn’t scroll saw.
Here is a photo of the finished drawers:
Next, I needed a way to attach them leaving a space for my fingers. I milled purpleheart spacers making them 5/8” deep. I epoxied them to the pulls and after locating them on the drawer fronts, I clamped and drilled into them for the screws (drilled from the inside of the drawfront). I added some silicon caulk into the holes and on the back side of the screw head to hold them in place. I am pleased with the end result and so are my three ladies!
As for the doors, the top one is to access the router chamber and includes a floor register to provide take up air to the shop-vac in the lower compartment. The doors are rail and stile type with flat panels that include the accent stripe. I joined the rails and stiles with pockethole joinery. The pocketholes will show when the cabinet doors are opened but what the heck, this is a for a shop tool! For the time being, I have installed store bought door knobs on the doors. Eventually I might make some from purpleheart.
Here is a shot of the completed unit with the door knobs installed:
The two doors are made from some maple I already owned. It has a more amber tone than the rest of the cabinet but again, it is a shop tool. The finish on the unit is 3 coats of Minwax wipe on polyurethane with #000 steel wool “sanding” between coats. So this project is nearly finished. I added 6 glue blocks (actually triangles) which will be used to screw down the tabletop and I installed locking casters on the bottom of the cabinet. I think I will make one final post after I have placed the “business” portion on top. Thanks for checking in on me.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
21 comments so far
View 489tad's profile
489tad
3368 posts in 3036 days
#1 posted 03-08-2011 03:59 AM
Great looking cabinet. The banding really catches the eye and the pulls are great.
-- Dan, Naperville IL, I.G.N.
View TMcG's profile
TMcG
191 posts in 3025 days
#2 posted 03-08-2011 04:07 AM
That really is a great looking cabinet, can’t wait to see it all assembled and ready to go.
-- http://wood.mcgivern.org
Beginningwoodworker
13345 posts in 3697 days
#3 posted 03-08-2011 04:41 AM
Lenny, thats going to be a nice router station once you finish.
View Woodwrecker's profile
Woodwrecker
4153 posts in 3600 days
#4 posted 03-08-2011 04:46 AM
You’re setting that bar pretty high for guys with two left hands like me Lenny!
And, that name/drawer pull idea, BRILLIANT !
That thing is sweet !
-- Eric, central Florida / Utor praemia operibus duris
View brianl's profile
brianl
108 posts in 3105 days
#5 posted 03-08-2011 06:10 AM
Looking great! I really like the purpleheart and yellowheart accent.
-- Brian - Belmont, Massachusetts
View HarleySoftailDeuce's profile
HarleySoftailDeuce
320 posts in 3444 days
#6 posted 03-08-2011 06:30 AM
Way to go Lenny !!
Keep up the creative ideas!
-- Paul, Bristol,Rhode Island
View Bob Kollman's profile
Bob Kollman
1798 posts in 3215 days
#7 posted 03-08-2011 08:20 AM
Really attractive Lenny, baltic birch is my favorite ply wood for
jigs-fixtures-and drawers.
-- Bob Kenosha Wi.
TopamaxSurvivor
18286 posts in 3700 days
#8 posted 03-08-2011 11:09 AM
Looks too nice for the shop!!
View littlecope's profile
littlecope
3071 posts in 3526 days
#9 posted 03-08-2011 12:46 PM
Great Job Lenny!!
That’s going to be a joy for you to use for many years to come… Very Well Done!!
View ellen35's profile
ellen35
2738 posts in 3456 days
#10 posted 03-08-2011 01:21 PM
Super job, Lenny… this looks like it could be in your living room!
This is the Cadallac of router tables!
Ellen
View rogerw's profile
rogerw
262 posts in 2714 days
#11 posted 03-08-2011 02:46 PM
very nice!
-- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" <<
View Lenny's profile
Lenny
1596 posts in 3551 days
#12 posted 03-08-2011 03:05 PM
Thank you for the kind comments everyone. I have had some fun, some frustration and some challenges with this build. A part of me is glad it is almost over. If all goes well, either today or tomorrow I will be giving it a test drive.
27250 posts in 3846 days
#13 posted 03-08-2011 03:06 PM
Lenny, this is one of the nicest looking cabinets that I have had the opportunity to see. This looks like a piece of fine furniture rather than a shop tool.
Now you do realize that since this cabinet looks so good you are going to be expected to upgrade the rest of your shop furniture! :)
View SPalm's profile
SPalm
5320 posts in 3906 days
#14 posted 03-08-2011 03:26 PM
Wow Lenny. That is nice!
What an inspiring build.
Steve
-- -- I'm no rocket surgeon
Lenny
#15 posted 03-08-2011 04:33 PM
Thank you Scott and Steve. Scott, my shop “to do” list includes a sanding center for sheets of sandpaper, sanding disks, sanding blocks and maybe my random orbit sander. Perhaps a Queene Anne highboy would look nice?
