Hi All,
A question I received on attaching the leather to the face of the mallets.
I thought I would pass it on.
Q.
Hi Lee;
I saw you used contact cement for the leather-end-grain adhesion. I am not really familiar with it (I have read about the dry and press methods of application), but assume it does better against end grain?
Have you had any problems w/ the leather peeling off, or are there other adhesives worth trying? (I had been considering cyanoacrylate, since I have that on hand…)
A.
The reason to use contact cement for this is the very same reason not to use it on veneers.
It remains flexible. Super glue is brittle after hardening and using the mallet will break the rigid glue line, and allow the leather to come off.
The first mallet I made, at least ten years ago still has the original leather glue to it, and that was using contact cement.
I sent one of the mallets I showed in the pictures to Jude. When I attached the leather to the face a couple weeks ago I used a non water based contact, applied a coat to each surface and allowed it to dry. I then second coated both surfaces and allowed that to dry.
With the leather laying on the bench, glue side up i pressed the face of the mallet onto it. Than I whacked it against the bench a couple times. Using my scalpel I cut the leather around the outside edge of the leather. Then using a spinning and rocking motioned I worked the edges tight to the wood. This will never come off!
I hope I didn’t get carried away in my description.
13 comments so far
trifern
home | projects | blog
7894 posts in 659 days
posted 479 days ago
Nice information. Thanks for sharing Lee.
SPalm
944 posts in 774 days
posted 479 days ago
I agree totally. It worked for me too. My wife unit dedicated an old pair of shoes for the leather to my mallet. This allows her to replace them without guilt.
I also suggest to chamfer the edges of the mallet before the leather. This will also ‘soften the blow’.
Thanks again,
Steve
3710 posts in 872 days
posted 479 days ago
Hi Guys;
I tend to round the faces slightly, as they are much less likely to mar your work.
Actually, using the scalpel, I trim the leather on a bevel also. Just looks better.
Sir_Robert
51 posts in 643 days
posted 479 days ago
Has anyone tried hide glue on leather? Contact cement gets crusty while hide glue remains pliable. Not sure how it would behave for leather. Just asking the question.
-- Sir Robert
SteveKorz
2030 posts in 606 days
posted 479 days ago
That’s a great tip, Lee, Thanks!!!
posted 479 days ago
Hi Sir Robert.
Great question. I have no idea how hide glue would work.
If you try it let me know. My curiosity is piqued now.
Lee.
Texasgaloot
467 posts in 593 days
posted 478 days ago
I believe hide glue would do the job in terms of adhesion, and would probably last quite a while. One note of caution: we use it in violin seams because it tends to be brittle. When maple wants to go one direction and spruce another, the glue line is supposed to give, which it often does with a fair report! That could be a downside, but the upside is that all you have to do is slather a little warm glue on the old and Bob’s your uncle. Another thought there, however, is that hide glue is water based. That will have implications in terms of the leather finding it’s equilibrium in your environment. I think I’m voting for the contact cement.
-- There's no tool like an old tool...
14914 posts in 743 days
posted 478 days ago
Thanks Lee. All that makes a lot of sense.
posted 478 days ago
Thanks Tex.
posted 478 days ago
Hi Grumpy,
Thank you, it’s somewhat rare for me to make any sense
jude
148 posts in 841 days
posted 478 days ago
The mallet Lee sent me is quite stunning. I’ve posted a photo and article on Toologics about it (and yep, threw in the now famous Ezee-Feed System link ;0)
http://www.toologics.com/News/Cool_Tools/Dead_Blow_Mallets_20080801875.html
-- life can always be weaved into a song.
jude
posted 478 days ago
and yup, I keep it within reach of my computer, on a shelf above my desk.
posted 478 days ago
Hi Jude;
Thank you for this. I should send you some more stuff!!
Remember to start out softly. I’m at the point I can use a sledge hammer, as long as it has a leather pad. lol
