Chevalet Build #3: Working on the seat
Blog entry by Mike Lingenfelter posted 12-16-2013 12:45 AM 1057 reads 0 times favorited 9 comments Add to Favorites Watch
« Part 2: Starting the build Part 3 of Chevalet Build series Part 4: Arm Support »
I had productive weekend in the shop, and made some good progress on the Chevalet. I mostly work on the seat this weekend, and now it’s starting to look like something recognizable.
The base was a little bit of a challenge, with the angled back leg and the through tenons.
The because the leg is angled, the through mortises are also angled. I drilled out the bulk of the waste then chiseled the mortise using an angled guide block to help. I had a little blowout when drilling out the waste, but It’s not too bad, and it’s down low where most people won’t see it. I wedged the tenons, and I don’t think those will ever come loose! I also used Epoxy on this joint, because I felt I needed a longer open time.
The front of the stretcher is attached with a long bolt, going through main support. The plans weren’t clear on the type of joinery at this location, so I decided to add a couple dowels to help. Although, I had it bolted together without the dowels and it was pretty sturdy.
I then attached the seat. I had planned to do through tenons on the seat and back leg, but because of a measurement error, the back leg was too short and ended up being a housed mortise and tenon.
I believed the front of the seat is just supposed be screwed to the front leg, but I used dowels again and threaded bolt. I’ve been tapping threads into wood lately and it’s been working pretty well. So I tapped the threads for the bolt, to just hold the front of the seat down. So far it’s holding really well.
I rough cut the seat shape and test fitted the Pressure Roller Post. I still have a lot edges to round over but the seat is pretty much done.
Now that the seat has been attached, the whole structure is quite solid and heavy! It should provide a solid base for the arm and saw frame.
9 comments so far
View Woodbridge's profile
Woodbridge
3006 posts in 1238 days
#1 posted 12-16-2013 01:06 AM
A very interesting blog. It looks like you are making good progress. I’m looking forward to the next instalment.
-- Peter, Woodbridge, Ontario
View shipwright's profile
shipwright
5523 posts in 1618 days
#2 posted 12-16-2013 02:53 AM
Looking really nice.
This will be a fine workplace. I wish you as many peaceful hours there as I enjoy on mine.
I’m very happy to see how many chevys are being built here on LJ.
Welcome to the club.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
View stefang's profile
stefang
13922 posts in 2154 days
#3 posted 12-16-2013 10:17 AM
Nice work Mike. I can imagine you are looking forward to getting finished so you can start using it. Fun to watch your build.
View Mike Lingenfelter's profile
Mike Lingenfelter
502 posts in 2934 days
#4 posted 12-16-2013 03:59 PM
Yes, I can’t wait to use it for the first time! My company shuts down the week of Christmas and through New Year. I’ll have 12 days to spend in the shop, minus a couple days spent with family. I should easily be able to finish it up over that time.
Mike
stefang
#5 posted 12-16-2013 04:55 PM
I feel the same way, but while I have done the initial lumber planing I am waiting until after Christmas to start building mine. So far I have managed to acquire all the needed components except for a simple piece of 18-1/2” long square steel tubing in the right size (Paul Miller version). Frustrating!
Mike Lingenfelter
#6 posted 12-16-2013 05:00 PM
Mike, I’d say look at http://www.mcmaster.com/, but you are in Norway? Not sure what shipping would be, in that case.
Mike
stefang
#7 posted 12-16-2013 05:47 PM
Thanks Mike, I checked into it, I also found some on Amazon.com. They don’t say if the size refers to the inside or outside measurement so I will have to find out about that. I’ve been to about 5 engineering firms and a few suppliers on the net here in Norway, but I haven’t found any retailers who have it yet. The smallest I’ve found here is too large.
View muthrie's profile
muthrie
9 posts in 1388 days
#8 posted 12-16-2013 07:28 PM
Lookin’ good!
-- Marilyn, Washington, http://sheworkswood.com/
View Dorje's profile
Dorje
1763 posts in 2817 days
#9 posted 12-19-2013 04:16 AM
Looks like it’s coming along nicely! I’ll be interested in seeing how it works. I know very little about these things!
