I’ve decided to go with the Holtzapffel style bench, and I’m going to give the large wooden screws, on the face vise, a shot. I talked with Christopher Schwarz about them again and he just loves them. He gave me a couple of sources for the wooden screws. I don’t want to post their email addresses in this blog. If you send me a private message, I will give you the two names he gave me.
I will tell you they aren’t cheap. One guy has them for $125/each and the other is $135/each. It will be an expensive endeavor if it doesn’t work.
I hope to start the bench in the next month or so. I will report back on how it goes.
14 comments so far
Dorje
home | projects | blog
1767 posts in 890 days
posted 679 days ago
Cool to hear you’re gonna start this soon! So you’ll get the screws, but then what about tapping the holes for the vise? Will you get something like this to do that – but bigger? What will the size of the wooden screws be?
Mike Lingenfelter
457 posts in 1007 days
posted 679 days ago
Not big enough :). These screws are 2.25” and 2.5” in diameter. They come with “nuts” that can be attached to the bench.
-- http://theinquisitivewoodworker.com/
Dorje
posted 679 days ago
Holy mackerel!
rikkor
11335 posts in 767 days
posted 679 days ago
Please post photos (with a size reference) when you get them.
Mike Lingenfelter
posted 678 days ago
I’m going to try and order a pair this week. When they come in I’ll post some pictures. This coming weekend is a 3-day weekend for me, which means more time in the shop. I plan to check out a couple possible sources for lumber on Saturday. If I find anything good, I may be bringing home lumber for the bench.
Dorje
posted 678 days ago
At that point you’ll have to change your blog series title to “My journey in workbench design & build!”
Mike Lingenfelter
posted 678 days ago
I was thinking about if I needed to start a new blog or just continue with this one. I think I my just start a new one for the build. Maybe I’ll have pictures of lumber this weekend :).
johnjoiner
153 posts in 786 days
posted 668 days ago
Hi Mike.
I’ll also be following your bench blogs as I hope to build a Holtzapffel this year too. I might be able to get a maple slab thick and cheap enough to use for a top. Otherwise mine will also be made of fir.
Did you look at all for mechanisms to build those large wooden screws yourself? It seems there must be something out there. But I can’t find any larger than 1.5”.
-- johnjoiner
25792 posts in 1293 days
posted 668 days ago
If you know anyone with a metal lathe they could turn the screws that you want. And if they have turned internal threads they could also turn the nuts.
Good luck
Mike Lingenfelter
posted 668 days ago
I found some resources on making large screws, but the nut was going to cause me problems. The largest kit that had both the tap and die, was 1.5”. I also needed a knob for the end of the screw and a handle. I don’t own a lathe yet, so it would have been difficult to make the knob. It started to become this big production for something I would only make maybe once. I ended up buying the screws. I’ll post pictures when they show up.
johnjoiner
posted 668 days ago
Hi Mike.
One more question: Did you ask Chris if 1.5” screws might be big enough? Or were those out of the question?
As cool as 2” wooden screws would be, there are too many other things to spend $200 on. So when I get around to building mine it’ll probably be steel screws and grease marks on my work. That is, unless, I’m thinking at the right time about how the bench should last the rest of my lifetime and then some.
-- johnjoiner
Mike Lingenfelter
posted 668 days ago
I went back and looked at my emails, and Chris did say he had used 1.5” but 2” would be better. His plans for the Holtzapffel bench, talk about 2” screws. You might shoot him an email and ask, if 1.5” will work. He has always responded to my emails, quickly no less.
Eric
784 posts in 677 days
posted 657 days ago
For what it’s worth, if it’s not too late: I just bought a 2” wooden screw off of eBay for $3.00. Granted, this has been my first success after seeing many other screws go for more than $50 (which is still pretty decent compared to buying new).
From time to time, you will see something on eBay that just goes past everyone else’s radar. Usually it’s because the seller has no idea what it is, and they market it poorly.
There are a couple other wooden vise screws out there at time of writing that are at $15 and $2 respectively (and both end within a day). Email me if you want more info…
-- Eric at http://adventuresinwoodworking.com
Mike Lingenfelter
posted 654 days ago
Interesting, I’ve been watching eBay for quite awhile and never saw anything show up. I still have a saved search on eBay for wooden screws, and haven’t seen anything. What were your screws listed under?
