Small Workbench #4: The Top
Blog entry by Mike Lingenfelter posted 698 days ago 1624 reads 1 time favorited 9 comments Add to Favorites Watch
« Part 3: The Base Part 4 of Small Workbench series no next part
For the top I wanted something that could stand up to getting wet. I thought I would use a laminate countertop (Formica). At our Home Depot you can get small 2’ x 4’ pieces of laminate. The selection isn’t that large, but I think I found something that worked for me. I glued and screwed to pieces of ¾” plywood together. Then I used some scrap pieces of oak to trim off the edges. I then applied some contact adhesive to the top and the laminate and put them together.
I put small chamfer on the edge and attached the top to the base. I used pocket screws to attach the top to the base. I also added a shelf to hold my sharpening stones and tools.
I made one last little fixture for the bench, a benchhook for the water stones. This also needed to stand up to getting wet. Also at Home Depot you can buy individual floor tiles. I picked up a 12×12 self-adhesive tile. I tried to find one that was relatively smooth. This was also a “hard” tile, not one of the softer vinyl tiles. I attached it to a piece of plywood, and added some oak trip. I left the oak about a ¼” up from the tile. I wanted to see if could keep the water contained. I used some silicone adhesive to attach the oak trim, to try and keep the water from seeping down into the plywood. I’ll have to wait and see if this works.
You might notice that the top piece of oak, is at a slight angle. This allows me to slide the stone in and wedge it in.
-- http://theinquisitivewoodworker.com/
9 comments so far
View Jamie's profile
Jamie
146 posts in 712 days
posted 698 days ago
Nice sharpening workbench. Pretty good idea with the benchhook having the angled wood to keep the stone from moving. Good job!
-- Jamie, Kentucky
View Thuan's profile
Thuan
203 posts in 716 days
posted 698 days ago
That’s a rugged little bench, but did you know oak has a high tannin content? This reacts with iron shavings from your sharpening and the water will carry the iron shavings deep into the oak’s open pores turning it black.
-- Thuan
View Mike Lingenfelter's profile
Mike Lingenfelter
458 posts in 1012 days
posted 698 days ago
I assumed the oak would start to discolor. It’s what I had laying around. I figured any wood I used was going to start to look bad, with all the exposure to the water and mess.
View Dorje's profile
Dorje
1767 posts in 895 days
posted 698 days ago
It is a workbench after all!
View itsme_timd's profile
itsme_timd
676 posts in 729 days
posted 698 days ago
Very nice! I’m getting ready to build a new bench for my shop and this gave me some great ideas.
-- Tim D. - Woodstock, GA
View Thos. Angle's profile
Thos. Angle
4013 posts in 860 days
posted 698 days ago
well done, Mike
-- Thos. Angle
Mike Lingenfelter
posted 697 days ago
Thanks everyone. I’ve been using the bench today and it’s working out well.
Thuan, the oak is already discoloring :). Not a big deal, as I expected it to start to stain. I just thought it would take a little longer.
The tile is working out great. The surface tension from the water makes the stone stick to it! There were a couple times I really had to work at getting the stone off!
View cheller's profile
cheller
249 posts in 1007 days
posted 694 days ago
Great bench hook idea.
The bench looks nice and sturdy.
-- Chelle http://artsgranddaughter.blogspot.com
Beginningwoodworker
4217 posts in 571 days
posted 237 days ago
Nice sharpening bench.
-- CJIII Future cabinetmaker
