Drum/Disc Sander #1: Help / Input request - Speeds for Drum & Disc Sander I plan to build.
Blog entry by Kevin May posted 04-18-2012 09:07 PM 2033 reads 0 times favorited 1 comment Add to Favorites Watch
no previous part Part 1 of Drum/Disc Sander series Part 2: Sander design is complete, construction has begun »
Jocks, I need your help with determining the Drum diameter for a sander I plan to build. (see earlier post for image).
The issue is that I have two options (sizes of steel tubing I have) for the diameter of the drum, either 4-1/2” or 6-5/8”.
The design of my Drum/Disc sander has both the drum and the disc mounted on the same shaft. This allows me to drive both with a single 2HP, 1725rpm motor I have.
The primary decision I am faced with is which size drum to build. The size of the drum affects the linear speed of the sanding surface. Searching the web, I believe that the majority of sanders have linear speeds of between 2000 and 2300 ft/min. Disc sanders almost all turn at 1725rpm, regardless of size. (I plan that my disc will be 16” diameter).
The following are the speeds of two basic choices I have been studying:
Motor rpm Pulley ratio Shaft/Disc rpm Drum size Drum surface/linear sanding speed-feet/min
or 1725 5:4 2156 4-1/2” 2032
1725 4:5 1380 6-5/8” 2400
The ratios above were selected to get the drum speed near what I think to be correct, with the disc speed varying quite a bit. I’m thinking that the 1380rpm may be fine for the disc, especially considering I’ll have a 16” diameter. Also, I assume the larger drum diameter would assist with heat dissipation. As I have never operated a drum sander before, my questions to you are really focused on the effects of the speed and diameter on the drum.
Thanks for reading. Hopefully my question is clear. Thanks in advance for any input you can provide.
Kevin
-- Kevin May "Making wood useful and fun!" www.kevinmaywoodworks.com
1 comment so far
View SASmith               's profile
SASmith
1850 posts in 2893 days
#1 posted 04-18-2012 10:30 PM
Not sure about the disc sander, but if you use hook and loop sandpaper you will have no problem with heat on the drum sander part.
My shop made V-drum sander spins faster than what most people recommend and I have no problem with heat.
-- Scott Smith, Southern Illinois
