Sanding Blocks
Blog entry by Jon3 posted 148 days ago 344 reads 6 times favorited 10 comments Add to Favorites Watch
I’ve had a kind of crappy blue plastic borg sanding block for some time, and I’ve been lazy and switched out the paper. I don’t use it too often, but its finally given up the ghost and won’t really stay closed any more. I decided to make myself some proper ones with a nice cork backing.
Here’s the original borg crappy one..
The one thing I do like about it is that it is sized such that you can quarter a regular sized sheet, and they fit the sanding block right.
I had a bunch of sheets for cork, because I made myself a small corkboard/takboard for veneer inlay layout purposes. I had some spare blocks of ash, left over from the bench, but I actually ended up making a sizing mistake and switched to maple.
I drilled a 1/4” hole, counterbored a larger hole, lined it with 5 minute epoxy. and a 1/4-20 nut into it.
2 small walls on either end, to help retain the sandpaper, were glued on. My leg vice made an excellent clamp. Note that the counterbored nut faces down!
Then I cut some rough pieces of 1/4” cork backing. (I found it at Staples.)
Plenty of glue, there’s a lot of surface area to grab on cork, and some bench holdfasts make good clamps.
Some over-sized ash blocks, fitted snugly in between the ends, will give me room to sculp something comfortable to hold.
Some bandsaw work, followed up with the oss/belt sander, and voila!
10 comments so far
View PurpLev's profile
PurpLev
2752 posts in 543 days
posted 148 days ago
much much much better :)
I used to have something similar, but without the cork on the bottom, if you just use wood backing, it’ll give you a straight plane to register the sanding paper against (good to sand straight planes and surfaces).
View Splinterman's profile
Splinterman
4826 posts in 256 days
posted 148 days ago
Nice neat job…well done Jon.
View kolwdwrkr's profile
kolwdwrkr
2249 posts in 485 days
posted 148 days ago
cool, looks like something I may need to do too. Thanks for sharing.
25801 posts in 1295 days
posted 148 days ago
A great variation. Nice job.
Craftsman on the lake
817 posts in 332 days
posted 148 days ago
I need to stop just wrapping sandpaper around the first wood block that I have that’s about the right size and make something like this. Nice job. Thanks for sharing the process.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
View Jon3's profile
Jon3
439 posts in 1000 days
posted 148 days ago
This took me about 5 hours total. Keep in mind I also spent time waxing the bed of my jointer and tablesaw, as well as making a small drill bit rack.
So, about 4 hours of puttering about, less than an hour of actual work. Although I broke it up over saturday and sunday so I could let glue dry!
View Kent Shepherd's profile
Kent Shepherd
826 posts in 181 days
posted 148 days ago
Thanks for the information. I need to build me some. Good job.
View HokieMojo's profile
HokieMojo
1142 posts in 623 days
posted 148 days ago
while these are very nice, they would take me much longer. I’m going to stick with my $5 rubber block for now, but maybe someday. If I knew mine would come out this well, maybe i’d try.
16841 posts in 472 days
posted 148 days ago
Nice cool idea
View Praki's profile
Praki
139 posts in 892 days
posted 147 days ago
Great idea.
-- Praki, Aspiring Woodworker
