Roubo #12: Drawboring the Top
Blog entry by Jon3 posted 225 days ago 322 reads 0 times favorited 11 comments Add to Favorites Watch
« Part 11: Drawboring Day! Part 12 of Roubo series Part 13: How I got this far... »
I’m nervous about trying to keep my hand drill perpendicular, so I made a little jig to drill the holes. Worked out quite well. Just put some thick scrap in the drill press and drilled out the holes, then clamped it to the top.
The dry fit was tricky. I did the dry fit, but it was going in tight. I also noticed I had two nice long wedges from the tombstone shape of the leg vice. They made excellent tools for forcing getting those tenons out of the too-tight mortises.
Another round of trimming, and I’ve got a nice tight dry fit!
And here is what it’ll look like when I finally get it flipped over!
Those legs ended up perfectly flush. I can’t even register a chisel between the top and the leg.
Dry fitting done, the long wedges helped me disassemble.
And with the tenons marked, I drilled out the drawbore holes.
Now I’ve only got 2 small things left. I have to route out the mortise for the sliding deadman, and install the end caps and vise hardware.
11 comments so far
View ChicoWoodnut's profile
ChicoWoodnut
895 posts in 710 days
posted 225 days ago
This is coming along nicely. Where did you get the anti gravity mallet?
View 3fingerpat's profile
3fingerpat
909 posts in 563 days
posted 225 days ago
LOL!!!!!!!!!!! Scott, I was thinking the same thing!!!! It is a great photo.
Jon, this is looking great, keep up the good work!
25801 posts in 1296 days
posted 225 days ago
Lookin g great. Nice job on the Bench.
20684 posts in 717 days
posted 225 days ago
Jon, this is looking really good. After all the dry fitting and disassembly I am sure you are getting a nice workout with this bench.
View Jon3's profile
Jon3
439 posts in 1000 days
posted 225 days ago
Not just anti-gravity mallet, all the tools are zero-G!
Let me tell you, trying to pound a few hundred pounds up in the air… not fun. The wedges were the only thing that made disassembly possible!
View sIKE's profile
sIKE
1094 posts in 649 days
posted 225 days ago
Man this is looking good, (whistfully said of course). I am just so envious!
View Jon3's profile
Jon3
posted 224 days ago
Don’t just be whistful sIKE, go ahead and build one. The wood is relatively cheap, and you’re only talking 12 joints =)
I’m a (2 year) beginner, and I have no formal training.
View sIKE's profile
sIKE
posted 224 days ago
One day Jon one day…...
View sIKE's profile
sIKE
posted 224 days ago
What are your plans for the sliding Deadman? Have you seen this one?
http://oudluthier.blogspot.com/search/label/Workbenches%20%2F%20Roubo%20Bench
I am so gonna make e one of these ….one of these days….
View Jon3's profile
Jon3
posted 224 days ago
You should see the sliding deadman showing up in the next post (or one after that) .
It is in progress.
Jameel’s is fabulous. I got my tail vise from him. Definitely an inspiration in my build!
View sIKE's profile
sIKE
posted 224 days ago
You got a BenchCrafted Vise too? ;)
