Cross Cut Sled #3: The 5 Cut Square Dance
Blog entry by Jon3 posted 12-09-2007 02:31 AM 7030 reads 18 times favorited 10 comments Add to Favorites Watch
« Part 2: Fences! Part 3 of Cross Cut Sled series Part 4: Dressin' it all up. »
Now here is something else I didn’t do last time. Properly squaring up the sled.
I start by lining up my nice new fence, and dropping ONE screw only on the far side.
Then I slice a kerf just high enough to pop through the ply, and line up the fence roughly with the square. (This part is NOT how it gets squared… read on!)
Looks square, doesn’t it?
HAH!
I made a small T adjustment block, and grab about 1/16 inch worth of sliced up index card and paper, and jam it in between the sled fence, and the block.
I flip the sled over, and screw my adjustment block in place.
Then I flip it back, and clamp that monster together.
Note: When you’re trying for something this precise, you have to keep the saw, and the sled clean. You are trying for hundredths of an inch accuracy, so dust like this can throw the whole thing off.
I vacuumed in between each test run.
I begin the 5 cut squaring process. You can read about it here.
After 7 runs, I finally got it accurate. And far more accurate than I ever expected:
Zero slop!
10 comments so far
6846 posts in 3886 days
#1 posted 12-09-2007 03:12 AM
Ah, nothing like accuracy.
View Thos. Angle's profile
Thos. Angle
4445 posts in 3869 days
#2 posted 12-09-2007 04:59 AM
good way to get it right.
View mski's profile
mski
439 posts in 3887 days
#3 posted 01-28-2008 11:43 PM
I know an old post but I been banging my head against the cast iron for a week trying to get my sleds square!
Just want to thank you for you tutorial, works GREAT!!!
Suprising what a regular piece of paper shim has on fence adjustment!
Thanks again
-- MARK IN BOB, So. CAL
View Jon3's profile
Jon3
497 posts in 4012 days
#4 posted 01-28-2008 11:49 PM
Glad it worked out for you!
View rikkor's profile
rikkor
11295 posts in 3781 days
#5 posted 01-29-2008 12:29 AM
Great explanation. Thanks.
View dlgWoodWork's profile
dlgWoodWork
160 posts in 3661 days
#6 posted 02-21-2008 11:50 PM
Great sled tutorial.
Something is wrong with your five cut method link.
-- Check out my projects and videos http://dlgwoodwork.com
View davidtheboxmaker's profile
davidtheboxmaker
373 posts in 3712 days
#7 posted 02-21-2008 11:56 PM
A friend’s got a new saw arriving tomorrow, so this is a really useful posting.
Like DGunn, I’m having problems linking to the 5 cut method – hope you get it fixed.
dlgWoodWork
#8 posted 02-23-2008 05:50 AM
The five cut method link is working now. Thanks again for the excellent tutorial. I needed to make a more accurate sled, and this did just the trick.
View BarryW's profile
BarryW
1015 posts in 3813 days
#9 posted 04-08-2008 02:42 AM
thanks for your postings on a crosscut sled…got some ideas.
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
View Sac's profile
Sac
268 posts in 3540 days
#10 posted 06-29-2008 10:35 PM
Very nice 5 cut squaring process…
-- Jerry
