Cross Cut Sled #1: New, and far more accurate crosscut sled
Blog entry by Jon3 posted 12-09-2007 02:18 AM 5641 reads 16 times favorited 5 comments Add to Favorites Watch
no previous part Part 1 of Cross Cut Sled series Part 2: Fences! »
NOTE All of my photos have been migrated to a new provider, and the links in my posts are likely out of date. You can find the photos here.
My old crosscut sled sucked. I made it before I acquired a lot of knowledge, but I’ve been dragging along with it for a while. I did some test cuts the other day, and realized just how out of shape it was, so I decided it was time for a new one.
So here comes the Cross Cut Sled Journey!
I decided I wanted a fence with a T groove on it, so I could fit in doodads and stop blocks and whatnot.
I have some fairly thick Ash leftovers, so I joint and plane it, then I taper the top to give it a little bit of style, and to get rid of a nasty chunk of wood. ;)
Then I drop a round over into the router table, and give the hand-side a more user friendly profile.
Then I route myself a little track in the other side for aforementioned doodads.
I chuck up my new Freud Ultimate Plywood blade, and grab a nice chunk of clean 13 layer BB Ply.
I slice off to ~4” chunks that I will glue and true up for the opposing fence.
I happen to have a stack of hard maple slides from the last time I made one of these, so I was up the table, and set some up in the grooves, riding on top of spacers (to lift them above table height to insure a good fit with the sled.
I drop the sled body so that the middle of the sled lines up with the saw blade, slide over my rip fence, and use a clamp with very light pressure to get the sled somewhat aligned.
Then I drop $1000 worth of weight on top of the sled, and let it dry overnight.
5 comments so far
View mrtrim's profile
1696 posts in 3812 days
#1 posted 12-09-2007 02:56 AM
i was looking at my sled the other day and thinking its time for a new one so thanks for posting. think ill build one quite like it nice job . i got everything i need except the 1000 $ weight . lol
View rpmurphy509's profile
288 posts in 3787 days
#2 posted 12-09-2007 03:23 AM
Wonderful weights, need some of those for my own shop (if the wife approves that is).
Off to read the other blogs in the series.
-- Still learning everything
View Thos. Angle's profile
Thos. Angle
4445 posts in 3895 days
#3 posted 12-09-2007 04:55 AM
View BarryW's profile
1015 posts in 3839 days
#4 posted 04-08-2008 02:41 AM
Your posting gave me a good direction for a crosscut sled….thanks
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
View GaryK's profile
10262 posts in 3920 days
#5 posted 04-08-2008 03:02 AM
Looks like a good start. Halfway there.
