Workbench Project #1: The workbench project begins!
Blog entry by Jon3 posted 768 days ago 340 reads 1 time favorited 4 comments Add to Favorites Watch
no previous part Part 1 of Workbench Project series Part 2: Making a base. Alternatively, learning to hate home depot. »
NOTE All of my photos have been migrated to a new provider, and the links in my posts are likely out of date. You can find the photos here.
I actually began this project around 6-9 months ago, when I got into woodworking, and I did some of the original work then. It is surprising how far I’ve come in what I know to do, and not do, since then.
I had a leftover benchtop that I picked up basically free from family friends.
It was not pretty! It had a fairly thick finish on the top though, so with some elbow grease and some scraping, I managed to clean up the top somewhat.
There is still a 1/8th inch cup to it that I’ll have to solve before I can count on the surface as being flat, but fixing that is for a later date. I needed something usable quickly.
It was joined by dowels, originally:
I bought some sized dowel cheap, just to fill empty holes, and glued then in and sawed (fairly) flush. I knew I’d end up trimming the sides back later anyway.
4 comments so far
View Dadoo's profile
Dadoo
1723 posts in 889 days
posted 768 days ago
I think I saw Norm Abrams make and use a jig that allows a router to travel back and forth across a cupped table, flattening the surface enough for sanding and planeing. I dunno, maybe it wasn’t Norm. (Swiss cheese memory here,; full of holes.) Anyhow, the theory is there and I’m sure you’ll find a bunch of good advice here.
Good luck with it and be sure to post the pics after it’s done!
View Jon3's profile
Jon3
439 posts in 1004 days
posted 768 days ago
heh. Just wait a few minute and see the next few entries!
View jpw1995's profile
jpw1995
348 posts in 1196 days
posted 768 days ago
I’ll go one step up from Norm and say you should reference this topic about flattening wide boards with a router by our very own Mark DeCou.
-- JP, Shelbyville, KY
Dadoo
posted 768 days ago
All-right JPW! Thats the one. I knew it was someone like Norm!
