Router Table #2: Dado Time!
Blog entry by Jon3 posted 10-17-2007 04:31 PM 1501 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 1: New Yankee Style Router Table Part 2 of Router Table series Part 3: Skipping Ahead.. Making the Top and Face Frame »
I grabbed a Dewalt Dado set off Amazon for a song a while back, thanks to the wonderful deal hound at Woodnet.
So I loaded that up, got a good fit, and began to run down some Dados
Then I began to glue & brad the chassis together.
I set that aside so that the glue could dry, and moved on to the drawers. I broke down the ply, and laid them all out.
Before I assembled, I did a big tape-up, tossed on some cheap sacrificial borg ply on the bottom, and drilled the holes. In retrospect, I think I’d look for a 17/32” bit for the 1/2” holes and a 9/32” bit for the 1/4” holes, so that you don’t have to wedge the router bits into the holes, and so that you’ve got some expansion/contraction room.
Decent amount of ply left over, too!
5 comments so far
View coloradoclimber's profile
coloradoclimber
548 posts in 4063 days
#1 posted 10-17-2007 04:47 PM
excellent project, keep the series coming.
I’m curious, how did the NYW plans work out? Are they worth the money? Are they detailed enough? Include a cut sheet? Hardware list? Assembly instructions? Do you need the dvd to actually finish the project?
View Jon3's profile
Jon3
497 posts in 4100 days
#2 posted 10-17-2007 05:00 PM
They worked well for me. They do include a hardware list, but there are so many options for hardware, I wouldn’t go nuts sticking real close to what he used. For instance, he suggests just driling out holes in the MDF and using T bolts, where I think most people would far prefer what I did with the T-track…
I have watched the DVD twice so far, and I found it did contain some useful tips.
The measures drawing is really more of a sized blueprint. It does not contain any real ‘instructions’ per se.
View knothead's profile
knothead
163 posts in 3943 days
#3 posted 10-17-2007 08:06 PM
I have been thinking of ordering several of Norm’s plans but wondered about the DVD….....is it an actual instructional item or is it merely a copy of the New Yankee Workshop episode that aired with the project?
Great work so far! Keep those pictures coming!
-- So Much Wood - So Little Time! --
View Jon3's profile
Jon3
#4 posted 10-17-2007 08:09 PM
Just a copy of the episode, sans commercials. No additional info. I was a little disappointed in that aspect also.
If you can catch the episode on Tivo, then I would not bother with the DVD, just the plans.
View David's profile
David
1969 posts in 4134 days
#5 posted 10-18-2007 06:48 PM
Jon -
Looking great!
