Compass Rose Inlay #1: Creating a Compass Rose Inlay
Blog entry by Jon3 posted 12-08-2009 11:55 PM 15646 reads 37 times favorited 16 comments Add to Favorites Watch
no previous part Part 1 of Compass Rose Inlay series Part 2: Inlay the Compass Rose »
I decided to dress up one of the serving trays I’m making with a compass rose inlay. I used the excellent instructions of Mike Henderson. I used Walnut and figured (birdseye) Anigre veneer, and I’ll be inlaying the rose into a curly maple raised panel.
I have most of the tools Mike mentioned, but I created some others, like a veneer cutting board, a cheap MDF 22.5 degree triangle.
I also created a ‘veneer jointer’ out of some sandpaper and plywood.
I cut the veneer 3×2 (one of them has some extra length) 8 pieces of each (2 roses). Then used my mdf triangle and the cutting board to produce my triangles. After cutting, I laid them out on some white paper so I could check for gaps and sand as necessary.
Then I taped up the triangles.
Then the whole kit.
Then I flipped it over and began on the veneer tape.
With the veneer tape dry, (it can take a while and a rush here is a bad idea.) I moved on to cutting the first triangles.
I got them all cut, jointed as necessary, and re-taped.
Then we flip it over. Starting to look quite like a compass rose now!
And veneer tape the heck out of it…
Then its back to the drying phase. Again, no rushing. Finally, its time to cut away the spare veneer to reveal the minor compass points. I went over this once lightly with a pencil, before I did any cutting, so I made sure I wasn’t cutting on the wrong point. It can be tricky and I came very close to accidentally chopping off a major point, so I think its worth taking the time to pre-mark these.
With everything cut, I began to peel back layers and trim the veneer tape off the excess veneer.
When done, you’re left with a compass rose! (Note there’s a tiny bit of veneer tape showing on the edges of some pieces. This will need to be carefully trimmed back before I try and inlay the piece into its final home.
Mike commented on my post, and pointed out more tutorials of his here.
16 comments so far
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3606 days
#1 posted 12-08-2009 11:59 PM
That will be a job too I would have been lazy and left it with this design with a round background for easy installation still yours looks better by far.Alistair
View Thos. Angle's profile
Thos. Angle
4444 posts in 3984 days
#2 posted 12-09-2009 01:16 AM
Excellent!!!
View dustbunny's profile
dustbunny
1149 posts in 3317 days
#3 posted 12-09-2009 01:47 AM
Wow !!
This is fantastic, I’ve been trying to figure out out to go about doing this with 1/4” stock.
This is a great tutorial, thanks so much : )
Lisa
-- Imagination rules the world. ~ Napoleon Bonaparte ~ http://quiltedwood.com
View bigike's profile
bigike
4052 posts in 3310 days
#4 posted 12-09-2009 01:47 AM
im totaly lost mabee if i see a vid on it but it looks good anyway.
View cabinetmaster's profile
cabinetmaster
10874 posts in 3579 days
#5 posted 12-09-2009 02:43 AM
Another great post. You have done a great job of explaining how to do this. I will favorite yours for future reference.
View Gary's profile
Gary
1291 posts in 4346 days
#6 posted 12-09-2009 02:55 AM
Jon, that’s superb. I just saw this on WN in the Hand tools forum. Great explanation; great workmanship.
G
-- Gary, Florida
View woodworm's profile
woodworm
14468 posts in 3612 days
#7 posted 12-09-2009 05:13 AM
Very very impressive. Excellent job!
-- masrol, kuala lumpur, MY.
View Mike_Henderson's profile
Mike_Henderson
18 posts in 3128 days
#8 posted 12-09-2009 06:47 AM
Thanks for the plug, Jon3. I have other veneer tutorials on my tutorial web page
And take a special look at the last two tutorials on that page.
Mike
View sedcokid's profile
sedcokid
2733 posts in 3620 days
#9 posted 12-09-2009 06:53 AM
Man oh Man, how beautiful it this!
Great Job!!!!
‘The SedcoKid’
-- Chuck Emery, Michigan,
27250 posts in 3843 days
#10 posted 12-09-2009 01:39 PM
Jon, this is a preety interesting blog. It looks like you have documented the process well.
View Charles Maxwell's profile
Charles Maxwell
1099 posts in 3829 days
#11 posted 12-09-2009 03:54 PM
I’m interested in best practices for compass rose inlays…so, this naturally piqued attention. One of the best posts, of the many fantastic posts in LJ, I’ve seen in a long while. Looking forward to more of your very useful ideas/posts. Thanks for sharing this. Definitely useful! Max
-- Max the "night janitor" at www.hardwoodclocks.com
View Jon3's profile
Jon3
497 posts in 4127 days
#12 posted 12-09-2009 05:43 PM
Good link Mike, I’ll add that into my post.
View CaptainSkully's profile
CaptainSkully
1600 posts in 3580 days
#13 posted 12-17-2009 05:10 PM
Thanks for accompanying each step with a photo. That really helps illustrate the steps. As a sailor, I will be doing a compass rose inlay on something, most probably the table in the saloon of whatever big boat we buy next year. I also want a compass rose tattoo when I grow up.
-- You can't control the wind, but you can trim your sails
#14 posted 01-19-2010 02:23 AM
Hey thx Jon3, i use your tutorial to made mine on my deskboard (secretaire) i’ll take photos and show it to you!
I made few little too and i use them like a coaster (sous-verre)
-- Charles-Etienne Sauvé-Faucher, Ebéniste.
#15 posted 01-20-2010 05:09 AM
It’s in my project! Come see!
